Eurobricks Forums
]I need help with a modified imperial Flagship i'm working on.
How do i attach the bow pieces at the front in LDD. I dont seem to be able to place them where they should be..
This picture should show better which part im on about
Edited by CaptMc
Hi there,
it's a bit tricky and you'll have to 'cheat' a little, but it's possible.
Here's my approach.
First you place a regular 1x1 round plate on the one stud, that the SNOT structure is supposed to be based on, place that grey piece on it, and use the hinge tool (in my case -130°).
Then place the first row of curved slopes, a connecting plate, remove the grey piece (and the round plate), and mark the following pieces.
Make them slide down along that bar, just to place the curved slopes closest to the prefab hull.
Last step is to place the rest of the SNOT structure, and clean up.
If you feel it necessary, use a bar to connect the structure to the prefab hull.
Hope this helps.
Regards
