BrickmanJ
[MOC] Fire Units
Here are my current fire units. These are for the Brickshore Fire Rescue District, which is the main fire department in my county, Brickford.
This is Engine 1, a 2013 Pierce Velocity side-mount pumper. It has a 500 GPM Waterous pump with a 2000 gallon polycarbonite tank. It is eqquipped with a Federal Signal Vsion SLR lightbar and a Federal Q siren. This is the second version of Engine 1. You can check out the new one here: http://mocpages.com/moc.php/376620, and the old one here: http://mocpages.com/moc.php/374415.
Up next is my Utility unit!
This is the BFRD's Utility unit for Station 1. It runs with Engine 1 for MVAs, medical calls, and anything that involves a trailer. It is a Ford F-250, converted by KME into a small service unit. It has a hard bubble cover on the bed, but it doesn't hold anything. It has Whelen lighting, and as you will see, there is a traffic advisor in the back. The wheel are raised a stud, due to the trailer hitch, and I think that making it one stud higher makes it look a lot more like an F-250 than a 150. The truck is pretty much self explanatory; not much else to say. Check it out on MOCpages: http://mocpages.com/moc.php/376041.
Last but not least, the command car.
This car is a 2013 Ford Interceptor used the BFRD for the chief. That they don't have. We have the car, but not the Chief. Anyways, same as the Sheriff cars, blah blah. There will be two more of these; one for each station. This one is driven by the chief, and the other two will be driven by assistant chiefs. It's on MOCpages here: http://mocpages.com/moc.php/377101.
Plus, the entire Brickford emergency fleet!
Look below for 'Muricah pride!
This is a car that would be, if you guys like it, more or less acuratly made into LEGO for the BCSD. I made this on Ford's Mustang Customizer. It is a Ford Mustang Shelby GT500 that would be an unmarked pursuit unit for the Sheriff's Department. The reason why it would be a pursuit unit is because of the supercharged intercooled 5.8-liter 32-valve aluminum block V8 engine delivering 662 horsepower and 631 lb.-ft. of torque. Plus it just looks badass, hands down.
Do you guys think I should go on a limb and try this? Post below!
Share this post
Link to post
Share on other sites
Love your work on the emergency vehicles. The only thing you may need to watch out for is the use of the standard over-scaled wheels...They seem to large for your smaller units and don't seem to work on the tender unit.
On the Mustang....Simply yes!!!
Share this post
Link to post
Nice vehicles! Try only to replace the stickers with more LEGO red background. Try using RGB scale found on peeron!
Share this post
Link to post
Thanks! I found the color list, but I can't seem to figure it out. Can you help me? I use MS Word for my decals. Edited by BrickmanJ
Share this post
Link to post
Nice 'Pumper' BrickmanJ. Anymore in the pipeline?
Sorry I'm so late. :D. Check out my MOCpages for my latest update and my homepage has my full units plans list.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
