montgocloud Posted October 15, 2013 (edited) Hi everyone, I have been experiencing problems with the Endor Rebel Trooper and Imperial Trooper Battlepack, specifically the main feature of the set: the speeder bike (Note: I'm using the Bricklink part numbers). Whenever part 2555, the modified black 1x1 tile with upright clip is placed on part 30187e, the reddish-brown motorcycle chassis, instead of staying put at whatever degree angle it is at, it locks to a 225 degree angle. This issue only effects one side of the motorcycle chassis. It is especially problematic when it is displayed, as it is always leaning to one side as a result because the ski attached to the clip won't lie flat on the ground and is constantly sloped in a downward position. I already tried replacing the clip; it doesn't help. So the problem must be with the motorcycle chassis. Has anyone else experienced this? Any advice would be appreciated! Edited October 15, 2013 by montyofmusic Share this post Link to post Share on other sites
Tariq j Posted October 15, 2013 Hi, I think I know what you're talking about, but just to confirm anyway, is the clip very loose on the chassis? Because if so I've got the same problem. I would buy separately another chassis and try it, I haven't done so myself but to me it seems like a logical thing to do. Share this post Link to post Share on other sites
TWP Posted October 15, 2013 I think I don't have this problem with any of my speeders. I own about 8, and neither of them seem to have an angle as great as your bike has. are you sure it is 255 degrees? A picture could be useful. The problem could be the friction of the clip; try placing the clip of the chassis as high as possible on the upper clip. If that doesn't work you could try to replace some pieces/ change the order of pieces. Share this post Link to post Share on other sites
montgocloud Posted October 15, 2013 I've seemed to have solved it. For around 10 minutes I held the back of the speeder on the ground so the ski wouldn't twist back into the awkward position. Low and behold, no problems anymore! If it decides to act up again I'll take some pictures. Share this post Link to post Share on other sites
Lord Vladivus Posted October 15, 2013 Double check the clips not cracked, I've had this happen, as it gets loose. Share this post Link to post Share on other sites
