Hey everyone,
I just released one of my newest alternate builds on rebrickable. However, I'd like to know your thoughts on the model itself. Please keep in mind the following limitations of the build. I redesigned the Ford GT from the set 42154 into a classic Caterham 7! This surprisingly was a tough build that I wasn't anticipating:pir-grin:.
Here are the instruction links https://reb.li/m/160562
- The Ford GT doesn't come with many beams or long-ish panels that can be used to fill out the outer body
-It doesn't come with clear lights
-Just limitations all around colour as the Ford GT had a lot of gaps this was a factor in the model.
As with any alternate builds these issues are not uncommon, so please also see the features that I have tried to implement in the model:
  • Realistic opening hood
  • Fenders move with Steering
  • Steering
  • Working Steering wheel
  • Working Inline 4-piston engine
  • Independent Front Suspension
  • Independent Rear Suspension
  • Detailed interior
  • Realistic Caterham 7 looks
Please take a moment to watch the video and tell me what you think of the model!
Edited by CrazyKreations
Adding photos
Share this post
Link to post
Share on other sites
Ford GT is 42154. Edit your Thread’s title. Otherwise it might create confusion before entering the thread. The MOC looks beautiful.
Share this post
Link to post
oops, that's my bad. I'll probably check with the admins if I can't figure out how to do that.
Thanks for your kind words, I would never had dreamed that the MOC would come out this good by the way
Share this post
Link to post
8 minutes ago, Mikdun said:
Would be nice to include at least one photo.
There you go, I don’t have many excellent photos of the model but there you go and there is a video too if you want.
Share this post
Link to post
Cool idea and nice looking model, I especially like the hood section as it smoothly gets narrower at the front.
However, I have some technical criticism. First, the suspension seems kind of non-existent, it seems that there's more flex in the parts than the actual suspension travel, although there would be space under the fenders. The other thing is that the front fender wobbles around too much with the wheel. I understand it should steer along, and I guess it should also move up and down with the suspension, but the way it tilts forward/backward as the model drives looks kind of odd. I guess it's been hard to fix it to the wheel though. Can you show a picture about how that's done?
Share this post
Link to post
Hey it’s an honour to have you actually look at my MOC’s. The front suspension is hindered due to an extra layer under the front suspension arms. They give a clear 1 stud of travel which is lacking for me, I didn’t have enough parts to make a custom wheel hub for the suspension. The parts do not flex. I believe you have noticed the fenders… if I had more parts I could have redesigned the joint to the wheel hub and the fenders for sturdiness but it’s not as simple as many may think. To make a low profile Lego hub requires some more specialised pieces that aren’t available in the set 42145. I am currently taking more photos for the connections and a gif for the front suspension, I will release more after a day or two.
Thanks for your words, as always it’s tough to make flawless creations with no issues especially when it is something cosmetic, but we can only try. 😁
Share this post
Link to post
Thanks, I have blocked youtube at work.
The model look great from all angles.
Share this post
Link to post
Thanks, I do find the one white piece on the sides a bit annoying but the parts in the set didn’t allow me to do anything else
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
