I figured It was time to make a helicopter and with the hype about the 42145 currently. (Like efferman's custom parts.) Plus I had the blades sitting here for almost two years. This is not any special make or model.
It so far has I have a rotor top, cyclic, collective, and rudder peddles. I used, for now, a modified setup that efferman made;
But so far I feel good about the progress.
https://www.bricksafe.com/pages/weavil/2022/helicopter-wip
Share this post
Link to post
Share on other sites
Hi!
This is a good begining!
Be carreful, it seeems but maybe i am wrong, that the collective mechanism will not work as it is monted now.
The movement od the end mechanism should be horizontal, not vertical i think.
I'll follow this one.
s
Share this post
Link to post
On 10/24/2022 at 7:56 AM, karmadrome said:
Wow, so compact and efficient. Great work.
Thank you.
On 10/26/2022 at 10:24 AM, steph77 said:
Hi!
s
I have been working on refinements, tweaks, and adjustments. The video was just a rough draft when I posted. Might post updates of it tomorrow.
Share this post
Link to post
Update on progress. Redesigned the linkage, connection points for them, and started on the tail rotor.
Here are a couple of tail rotor concepts.
Edited by weavil
vid link
Share this post
Link to post
I have been busy, but have some progress to the build. The linkage was a problem with slop and/or function. Rebuilt, modified, or prayed to the goat gods, but I prevailed and I think I got most of the kinks out.
I got the tail and linkage worked out and then the rest started to fall into place.
Here was the first tail idea.
Here was the start tail and the rotor.
Here is the tail.
This is the controls out.
And in the helicopter.
The redesign.
The swashplate and doors.
And the tail adjustment axles.
Share this post
Link to post
25 minutes ago, Jurss said:
That tail rotor is really interesting. Pic from other side?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
