I decided to build a concrete pump for the first contest I enter. I see such vehicles regularly on construction sites, so I think this vehicle should be ok for the contest.
It will be inspired by the model of the Liebherr 42 XXT:
This is my progress so far:
Thanks for reading and any comment is much appreciated!
Share this post
Link to post
Share on other sites
Nice to see such a long model, this proves how much is possible within 10000 sq studs!
Good luck, seems like a long steering linkage also :wink:
Share this post
Link to post
Yes , I was wondering about how long the model can be but it should end up coming out at about 9900 studs³.
I used a 15 l liftarm as the steering linkage:
Edited by Philtech
Share this post
Link to post
Very cool idea. I was wondering if anyone would do some sort of construction truck. I look forward to the result.
Share this post
Link to post
Interesting solution for steering. Is that whole long beam turning?
Share this post
Link to post
Fewer people enter the contest with a truck like that than I would have thought.
Yes, the whole long beam is turning.  This makes the steering quite hard to turn with a simple axle, but with a gear on the axle it works fine.
Share this post
Link to post
The driver's cab is now finished:
I will add some details later.
The next step will be to build a prototype of the outriggers to estimate how much space they will need and then build the boom in the middle of the outriggers.
Edited by Philtech
Typo
Share this post
Link to post
Here is my progress so far:
I changed the steering mechanism because the old one was a little hard to turn and the axle was too far from the cab. With the new mechanism I moved it further forward and added a steering knob to the top of the cab.
Furthermore, I built the boom. This one is fully operated with pneumatic functions (except turning) and can fold in four times, but I haven't laid the pneumatic hoses and placed the pneumatic switches yet, so I don't know if I can put all that somewhere.
For the last folding out, this small cylinder is actually a bit too weak, so it only just folds out under high pressure, but unfortunately no other cylinder fits in this place.
I also built outriggers, but not all complete yet. The front ones will be able to extend, the rear ones won't, as it is the case with the Liebherr 42 XXT model.
I'm still thinking about whether I should replace the linear actuators with a pneumatic cylinder, where I have pneumatics in the model anyway I thought that might fit and be more stable. I had thought of these:
Since I do not have the cylinders that are suitable for this at all, I'm thinking if it would be worthwhile to buy them.
Any comments/thoughts/etc are much appreciated and thanks for reading.
Share this post
Link to post
Nice update, are you planning to use a color scheme like the picture of the Liebherr 42 XXT you posted?
I think the LA's are fine, very easy to operate on the outriggers.
Share this post
Link to post
Great job. That boom has a quite a reach.
Yeah, keep the linear actuators for the outriggers. They fit perfectly.
Share this post
Link to post
I plan to use a similar color scheme. The outtriggers won't be orange, because I don't have enough orange parts. They will be red, like in the pictures above. The orange hose will probably also be red. I will change the cabin color into white or black. I don't know exactly yet.
On 4/28/2022 at 9:37 PM, LEGO Train 12 Volts said:
Very cool ...the fully extended arm is impressive! :wub:
On 4/28/2022 at 10:31 PM, jorgeopesi said:
Wow huge tiny truck, I like all the linkages.
Thanks for all the feedback. Then I will leave it with the LA's for now.
One of the rear outtriggers is also almost finished.
And here are a few pictures with a bounding box. The size of it is: 11 x 18 x 50 studs (WxHxL).
https://bricksafe.com/files/Philtech/concrete-pump-tc-22/wip-3004/20220430_140852.jpg/800x600.jpghttps://bricksafe.com/files/Philtech/concrete-pump-tc-22/wip-3004/20220430_140958.jpg/800x600.jpg
The mirrors are retractable, otherwise the model would no longer fit in the box.
https://bricksafe.com/files/Philtech/concrete-pump-tc-22/wip-3004/20220430_141025.jpg/800x600.jpg
Share this post
Link to post
The concrete pump is done now!
Features:
2-Axle steering:
Extend and lower outtriggers:
The front outtriggers have a lock function. You can pull the bush upwards to unlock it (see the pictures below).
The rear outtriggers have an automatic snap and stop function, because of the LBG beams in the picture below.
Unfolding the boom in four stages:
Rotatable boom
Openable doors:
Retractable side mirrors:
Openable toolbox:
Detailed cab:
Rear lights:
Thanks for reading (or rather for looking at pictures :wink:)!
Edited by Philtech
Share this post
Link to post
Wow, that got huge! How many meters of pneumatic tube have you installed? :laugh: Man, I think I can just stop with my entry, the competition is just too far ahead with everything....
Share this post
Link to post
Thanks! I think I installed about 3.5 meters pneumatic tube.
That's partly what I thought, too. But now I am reasonably satisfied with my result. I think you should also continue building.
And one more fact about the concrete pump: It is about one meter high in fully unfolded form.
Share this post
Link to post
:pir-oh: I didn't expect more than 2 meters, geez...
Amazing! :thumbup:
Share this post
Link to post
Amazing! :thumbup:
17 hours ago, PassengerJet said:
This thing is amazing!
Thanks! Great that you like it.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
