I'm already building one grader, but larger. Also, when thinking about this contest, I was thinking about good use of those tires from VW T2 camper, which (just tires) I had bought some time ago. So I decided to build some smaller grader.
So far I have this
So almost ready front part. Front axle has swinging suspension, of course, it has steering, then there is blade with some functions - rotation, level adjustment on each side, so it can be also at some angle, and blade can change its position sideways.
And yes, there are parts with excellent color consistency from siān.
It is some 13 wide (blade rotated). Lenght will be around 345, so I have some 17 studs left for height.
Edited by Jurss
Share this post
Link to post
Share on other sites
When I saw "lime" I thought this was a grader used in limestone extraction. :laugh:
Share this post
Link to post
Nice, I was hoping you would join with a grader!
And I think you have 21 studs left for height (21,97)....
Share this post
Link to post
Strange, I calculated before, and I got that number with 11 studs width, which is now for wheels.
1 hour ago, GerritvdG said:
21,97)
now recalculates, and really, I have still some reserves :)
Share this post
Link to post
Two graders at once! It will be fun to see these coming together at the same time.
Share this post
Link to post
Not shure about this :) but could help for each other with some solutions.
I realised, where is the "issue". Length will be close to 45 (not 35) as I wrote.
Share this post
Link to post
Tried to build something for rear part. Wanted to implement also fake engine, differential.
In fact I did it
but what worked on some "sketches" with all those gears, didn't worked on this "final" construction. There is big friction or something in all of this, when I really try to drive it, also wheels wobble. Lifted from ground, it works pretty well. But, es the axles from wheels don't stay straight, they have some play, then gears presses more on next gear, or disengage.
I wanted to implement this all in 11 studs width. For more proper gearing the width would be needed 13 studs. But then again I would need to increase blade width for grader to look proportional, bey that would mean some kind of grader-lowrider.
It seems, that I will skip idea of fake engine. I could try to implement drive on just one side. I tried in fact, but I didn't liked that idea.
Share this post
Link to post
I like the thinking there! I don't know if you have any old 14T gears, but I think those run more smoothly with the 20T single bevel gears.
Share this post
Link to post
Why not building a vintage grader without cab and make it 13 studs wide?
Share this post
Link to post
12 hours ago, Frodman said:
vintage grader
could be an option
12 hours ago, 1gor said:
you could use this older one
Not shure. How could I fit it? I need to have those wheels swinging. Yes, I could try to consider option, where differential is fully supported just on one side, on other somehow relay on axle connection, but not shure.
I don't have them, and not shure, if they would solve "issue", as those tan gears ar somehow rised, that is why they don't engage nicely.
Share this post
Link to post
Some progress on rear part (as it is raining today and won't stop). Put some gears just on one side, so fake engine has some drive
Share this post
Link to post
Bottom view of gears and engine
Engine and engine cover (and fifty shades of lime)
In the background black gear for front wheels HOG steering, grey - articulated steering
Added rear plough
And here close to finish
Dimension now around 14x14x34=6664
Share this post
Link to post
Now this looks so great. BTW, are MOCers slowly approaching to the newer diffs :pir-grin: I have one as spare thinking about replacing the old one used in the 42093 Le Mans Racers MOC.
Share this post
Link to post
Thank You, just need to wait for rain to finish in my photo studio :) then will take some better pictures. And there is still time, maybe I will change something, as I'm not satisfied with all things.
One simple thing from list - maybe will change blade color also to lime. But not yet shure, need to try.
I bought some separately, as I haven't bought set which has it. In some cases it may be better, as there are two options how to connect gear.
Share this post
Link to post
Then it'll probably merge with the bodywork - what about making it white to contrast with lime and match with wheels and roof? (I know this wouldn't be that practical solution at a real one but still... :pir_laugh2:)
Share this post
Link to post
Thanks. I think black, as a colour accent can go really cool with lime green, more than DBG. That said the black blades looks fine to me. You can try definitely :pir-grin:
Share this post
Link to post
That is what I'm afraid of, and didn't tryed already.
white
Didn't thought about that, in fact. Just checked, that I somehow have already 6 of them . I think, I will try this for sure. Could be best of all options.
Share this post
Link to post
Not shure, if the cabin is not too small. In real it looks OK, but not exactly in this picture
Share this post
Link to post
@Jurss Looks great! Lime and white aren't the most common colours for a construction equipment but go well with each other and make the grader look somehow special - I really like it.
What about the cabin - as I see it, it looks small because it somehow optically seems to be connected with the seat, which is something that doesn't happen when looking at the model from an angle.
Share this post
Link to post
@Jurss: Brilliant functionality in such a tight space! :-)
For the cab: I think for a really big grader it is ok, but for this model it seems too small indeed. Have you some cubic studs left? ;-)
Share this post
Link to post
I think yes. It was something around 7000 now.
Share this post
Link to post
Yeah, if you have the cubic study space left, I would make the cabin a little bigger too.
Love the colors!
Share this post
Link to post
I think the cabin from 42121 would be a great fit here, too. Nice functionality. From the color, should this be an Euclid grader?
Waiting for the final pictures. Will you grade some sand maybe?
Share this post
Link to post
Changed littlebit cabin, made it one stud higher. It was not easy, as it was required to disassabmle pretty much, to move one 3L pin. For me it looks like really significant improvement, proportions for cabin is much better.
Everything else is almost the same. During these changes, change littelbit upper connection between front and rear part.
Picture with box
Final dimensions are 45x13x15 = 8775
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
