Jim
[TC22] Technic Small Construction Vehicle Contest - Entry Topic
25. Mini Rough-Terrain Crane
Functions:
  • 4-wheel steering
  • Synchronized outriggers
  • Superstructure rotation
  • Boom elevation
  • Boom extension
  • Winch with ratchet
  • Detailed cabin
Final size is 14x14x45 or 8820 cubic studs.
Share this post
Link to post
Share on other sites
THIS MODEL HAS BEEN DISQUALIFIED DUE TO A LARGE NUMBER OF SYSTEM PARTS
CAT Skid Steer Loader
Main features:
- Total no. of pieces is around 900
- Around 1/16 to 1/17 scale; works well with the 42114 Volvo Articulated Hauler
- 4WD with a modified transverse subtractor by Sariel (http://sariel.pl/)
- Requires a BuWizz 1.0/2.0 or CaDA or Mould King remote battery hub
- PF L Motor for the main driving
- PF M Motor for the steering
- PF M Motor for the bucket lifting
- PF M Motor for the bucket tilting
- Movable cabin
- Bucket is swappable to a pallet fork or a larger bucket
- Detailed cockpit and driver seat
- The size is 20.5 x 17 x 28.5 = 9932.25 cubic studs
https://www.eurobricks.com/forum/index.php?/forums/topic/190872-tc22-cat-skid-steer-loader/
Share this post
Link to post
26. Technic Excavator
Functions:
  • Operate the shovel
  • Operate the main boom
  • Operate the second boom
  • Tilting cabin
  • adjustable track width
The first four functions are controlled pneumatically, the last one is controlled per hand. Of course, the excavator is as detailed as possible, featuring a seat and two joysticks inside the cabin.
Dimensions: W x L x H: 15 x 37 x 18 = 9990 cubic studs
Share this post
Link to post
27. City crane
Functions:
  • steering on axles 1 and 3 - from white gear on the rear of the carrier
  • outriggers (all 4 linked) - from knobs on the side of the carrier
  • slewing (manual) - no knob
  • raising boom with long LA - from knob on the bottom rear of the superstructure
  • extending boom - from knob on the top rear of the superstructure
  • string reel - from knob on the top of the superstructure
  • manually attached jib - use brown axle to attach to inner boom, swing out and lock, and reroute the string over it
Dimensions:
  • fits in a box of 41 (length) x 14 (width) x 17 (height) = 9758 cubic studs.
Images:
Discussion topic:
Share this post
Link to post
 28. Road roller
Functions:
  • Rear wheel drive – 1M PF
  • Steering system – 1 M PF
  • Powered by sbrick
  • Мanual opening of the door, sunroof, side windows
  • Working steering wheel in the driver's cab
Dimensions:
  • 28L x 18W x 19H = 9576 cubic studs
   You can see a lot of interesting photos in my topic
Photo for eurobricks 1Photo for eurobricks 2Photo for eurobricks 3Photo for eurobricks 4
Share this post
Link to post
29. Wille Loader
Features:
- Drive (L-motor)
- Articulated steering (M-motor + 2x linear actuator)
- Bucket lift (L-motor)
- Bucket tilt (L-motor)
- Front and rear lights (2x LED)
- LiPo-battery
- 2x IR-receiver
Dimensions:
35L x 13W x 17H = 7735, stud^3
Photos:
Video:
Share this post
Link to post
30. Mars Tracked Dumper
Functions:
  • Driving (left and right track with an PF L motor)
  • Dumping (PF L motor)
  • Track tensioners (with yellow hard spring)
  • Moving steering handles
  • Adjustable mirrors
  • Tailgate synchronised when bed is dumping
Dimensions: height 17, length 30, width 19 = 9 690 cubic studs
Dumping action:
Discussion topic:
Edited by Milan
Helped to fix the distorted image issue.
Share this post
Link to post
