There've been a bunch of times I've had just a little idea I wanted to post on here, without making a new thread for it. I've put them in different generic threads in the past, but I figured it might make sense just to make a personal thread to share stuff of this sort.
Anyways, the first thing I want to share is this ten-sided "Geneva Mechanism" I came up with today.
It's using a 10T splat gear with a pretty standard mechanism for rotating it intermittently, as in a stepper. However, rather than having a spring-loaded part pressing against the teeth of the gear as in a stepper, I've got a an axle that locks the teeth of the gear when it isn't being engaged. The same axle that runs the beam that steps the teeth is also hooked up to a wave selector, so that when it approaches the position in which it will have to move the teeth of the gear, the bump on the selector moves a linkage that briefly unlocks the gear, and then automatically locks it again after the motion is done.
It's working well in one direction right now, as seen in the video, but it's not working the other way. I think this is because of the sideways force the wave selector exerts on the black beam, but I'm pretty confident it could be fixed with a more thoroughly engineered solution than this proof of concept.
Share this post
Link to post
Share on other sites
And, I already came up with a design I like better... I should probably hold off on posting stuff like this until I refine it. Because of that principle, I'll wait on showing my new design until I decide if it's final or not.
Share this post
Link to post
With the rubber band on one side, your black beam experiences more force on the side. If you can get the force equally exerted on the other side, you should then be able to move in the other direction. Because of the looseness of the pieces, even the smallest forces can cause beams to be slightly angled.
Share this post
Link to post
That probably is a factor, but I think the main thing is how the selector pushes the beam sideways. This sideways motion ends up pulling the axle back a bit before the beam has even popped up on the selector's bump, and I think it's this preselection that makes the one side work better than the other. Like I commented, though, I've got a totally different design that works quite a bit better, so I probably won't develop this design any further at present.
Share this post
Link to post
Cool use of the orange wave selector.
Share this post
Link to post
😂 I hear you on that!  As soon as I post something I invariably realize the flaws with it.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
