zinnn Posted January 17 (edited) So I'm building a MOC in Studio and want to fully slide those technic pins inside the 6 x 1 brick from the bottom (image of how far the software allows me to do it should explain it below). Is there a way to do it in Studio? I'm just learning how to use it, so apologies if it's a basic thing to do. Edited January 17 by zinnn Share this post Link to post Share on other sites
Calabar Posted January 17 It is an illegal technique for sure. Inside the brick, the technic pin have not any space to expand. Keeping it compressed the pin will be damaged after some time. Share this post Link to post Share on other sites
ExeSandbox Posted January 18 You might have to switch to manual control by pressing "T", then drag the arrows to position the piece exactly where you want it. You can switch the grid size to the smallest setting to have finer control over the movement. Share this post Link to post Share on other sites
zinnn Posted January 18 Thanks guys. I actually figured out a workaround for the upside down bricks: Share this post Link to post Share on other sites
