Hello everyone and welcome to my newest C-Model. I'm keeping my current momentum of doing conventional vehicles from a tracked set and it's amazing how versatile the 42095 set can be. I call this MOC "Dirt Devil" because it was meant to run on dirt roads and has an agressive look.
Now let's talk about the vehicle itself. It is 25 studs wide, 35 studs long and 14 studs tall. One of the l-motors available on the set is dedicated to steering, which has return to center functionality by using a common rubber band. There is no need to specify a size for the rubber band because it can be twisted as needed, it just needs to have enough strength to push the steering mechansim back to its center position, you can test this as you build it.
Another l-motor is directly powering one of the rear wheels, so this is a 1RWD vehicle. I usually go with this approach because this set lacks parts to build a decent transmission mechanism, so, to power the two rear wheels, i would need to spend too many parts and would have enough left to model the car.
Another issue with this set is that it is a tracked vehicle, so there are no rubber tires, which means the wheels on this car are useless on smooth surfaces, but if you've built my other MOCs, this shouldn't be a surprise. It runs fine on rough terrain though. Anyway, there are several fixes for this issue. Since you're getting a rubber band for the steering, you might as well get some more and hack them into the tracked wheels like i did in this video of my other MOC here; or you can add rubber studs on the wheels if you have them; or simply swap the tracked wheels for any other rubber tires if you have some spare ones, this is hands down the best and quickest solution.
For anyone interested, building instructions are available at Belle-Ve Bricks
Edited by davejsp
link update
Share this post
Link to post
Share on other sites
It reminds me RC buggy models, especially the title photo, quite authentic!
It even inspired me to stop the existing projects and make some similar one - crazy lightweight thing.
The only moment I don't like is an extremely low gound clearance under the front axle (that H-shaped liftarm that embraces the motor connection)...
Share this post
Link to post
Yeah, i kinda was forced to do that because this is a pure C-Model, i had to use the available parts to build it, and the front axle really needed stability, so sacrifices were made, but i'm considering releasing a non-C-model version with additional parts and improvements.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
