nimitstexan
Recommended Hull Widening Technique?
So, I have an idea to build out a couple of frigates at a sort of 1/2 Lego scale (i.e. roughly ~1/75 scale, but still scaled internally so that minfigs can "operate" her, and my kids can play with her), sort of how the System Lego Pirate ships are designed already (other than that they are generally too short for their beam). Think of it as "if Lego built an HMS Indefatigable  or USS Constitution in "System Scale" (like the System, Scale Millennium Falcon  or AT-AT from Star Wars) what would it look like?" idea. To that end I have been reviewing the various hull widening techniques (such as in the Capt Greenhair tutorial, or using inverted slopes such as in the La Grenouille Blue Coat frigate) on this forum and in LDD, but what I cannot tell from just looking at it (and what I am looking for opinions on before I get too far down this process) is which, if any, of the hull widening techniques will still end with a stable/"playable" ship, and would still allow the sides to be designed to open and/or the top deck(s) to be removed (as in the Imperial Flagship) for access/play in the interior?
Share this post
Link to post
Share on other sites
Why don't you try to build your own brickbuilt hull? Like in 31109? Then you'll have more options for scaling and stability.
Share this post
Link to post
I've seen some cool builds on the Facebook groups where folks use double hulls (two hulls next to each other) and then also extend with inverted slopes - it allows for a 32-stud wide area on the ship for plenty of detail and playability. Like all of the other techniques, you'd still have to build in supports to make it sturdy!
I am building a redcoat La Grenouille now and it is pretty sturdy with the inverted slopes added - only adds two studs of width, though.
Share this post
Link to post
Can you post some pictures of the things you are referring?
Share this post
Link to post
Not finding the specific one I'm looking for, but there are a few giant ones out there at minifig scale. I'll keep looking. I think it was a comment reply to a post about something a few months ago.
Poseidon is one: https://www.facebook.com/BeyondtheBrickTV/posts/massive-lego-uss-poseidon-ship-by-john-morris-162-cannons-600-minifigures-more-t/3142133222507760/
This is another custom hull one: 118443514_10164003421255564_848510592510
This is one built directly on a 32 stud baseplate: 121038098_3542052935852373_3356076500930
This is one made wider by adding tiles and plates to sides
121017461_3542041872520146_1530817402906
121055574_3542042005853466_8130650517855
Share this post
Link to post
I have considered that . . . my concern is (a) the cost and (b) how well the technique holds together for playing/movement if scaled up much beyond the Creator set size (and that is an expensive dead end to go down if it turns out not to work).
Well, if I got to 32 suds wide, that is getting close to 1/40 scale and would drive a 122-130 long (on the gundeck).
I am consider a ship 20 to 22 studs wide. For that size, I think I am looking at the inverted bricks approach. Since I want to build in the "pop-off" spar deck on the Imperial Frigate, I am not convinced
Edited by nimitstexan
Share this post
Link to post
Babyteeth, the guy who submitted the updated Caribbean Clipper on LEGO IDEAS, has also made even bigger ships with custom made hulls.
Here is he's biggest ship, a 4th rate Ship of the Line, by his description.
https://www.brickinside.com/NeoView.php?Db=ReviewOwnCreation&Mode=view&Number=4399
Edited by Brickander Brickumnus
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
