Finally finished another one ;) This lego GBC module uses a large Lego technic sprocket on it's side to and lift the balls. It is a reliable module and meets the standard, it can hold over 30 balls in the input bin and runs just over 1 ball per second. The mechanism runs a lot smoother in real life then it look in the video, it also runs a bit better slightly slower. You may notice in the video that sometimes it doesn't pick up the full 6 balls. This could be fixed by changing the agitator design or running it a bit slower so that the balls have more time to roll into the sprocket I did not change the design because it is very reliable like this and still meets the standard. RebrickableFlickr.
Lego GBC Lifting Sprocket Module Photos
Share this post
Link to post
Share on other sites
Nice module, with an interesting drive system.
I recently brought two large sprocket wheels, so I have a use for them now.
Edited by Doug72
Share this post
Link to post
15 hours ago, Ankoku said:
Great discovery that the balls fit like that. Works really well!
Thanks!
Thank you! You can also flip them the other way and put 6 basketballs in the middle to make a turntable.
Share this post
Link to post
16 hours ago, Coolusername said:
^^^This could make a cheeky ball bearing :D
Yes, it is very smooth. I think it might be hard to attach a motor to it though...
Share this post
Link to post
On 6/18/2020 at 11:40 PM, Frequenzberater said:
Great work again! I like that you always come up with unique ideas.
Thanks! This one was accidental, I came up with it when I was trying to make a turntable out of the sprocket pieces.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
