Sign in to follow this
ord
[MOC] Mechanical tilt display
Version 1:
Since the release of the Powered Up Technic Hub, I've wanted to experiment with its internal tilt sensor(s).
This is the result; a mechanical seven-segment display that shows the pitch of an 'aircraft' accurate to 10 degrees.
It works by having 4 motors each controlling 2 segments of the display (8 moving segments total) via cams.
Each motor moves to one of 4 positions, putting its respective segments to OFF-OFF, ON-OFF, OFF-ON or ON-ON.
It's not as responsive as I had hoped but was a fun little build :classic:
Version 2:
(See post below for more information)
Edited by ord
Share this post
Link to post
Share on other sites
and the programming!! Please!!   like a quick look at your code blocks for verification!!!!  :)
Share this post
Link to post
Here are some pics of the mechanisms. It is really quite simple: blue cams are horizontal segments and red cams are vertical segments. The segments fall back due to gravity
The code is the complicated part (screenshot here). Basically:
  • The first loop returns the tilt angle as an integer between -9 and 9 (and its modulus for simpler coding later on)
  • The second loop rotates the motors (in parallel) every time this value changes. Motor positions are determined by...
  • The next four loops. They constantly determine which segments should be on or off, depending on the integer(s) returned in the first loop
Edited by ord
Share this post
Link to post
Version 2:
I'd like to present version 2 of this MOC. Taking inspiration from aeh5040's seven-segment display, this version features:
  • Control by a single shaft/motor
  • Number incrementing and decrementing
  • Faster response time than version 1
Unfortunately, mostly due to the goal of having only one input, this version doesn't feature a 'minus sign' segment.
Edited by ord
Removed image linking to Flickr
Share this post
Link to post
Wow. :wub:
That's some pretty impressive mechanical work, Nice Job.
It seems pretty reliable.
Do you think it could be stacked (horizontally) ?
Share this post
Link to post
13 hours ago, Touc4nx said:
Wow. :wub:
Thank you :classic:.
I don't see why it couldn't be stacked (to make a 0-99 counter, if that's what you mean).
That would actually be pretty cool; it would just require a mechanism that steps every 10th rotation and can handle a reasonable amount of torque.
Share this post
Link to post
I have only today stumble upon this magnificent mechanism. Version 1 is cute and uses some nice thinking. But version 2 is just out of this world. I imagine you have 7 bit (0/1) instructions on technic liftars, which are rotating on the threads. I think this is a step forwards from aeh' but even his is quite clever. I am rebuilding aeh' mechanism with driver in the back (have some problems with friction). I would appreciate if you could share some more pictures of version 2. I still don't get it but it's really incredible! Congrats!!
Share this post
Link to post
Thank you for the comments. That's right about the 7 bit instructions:
I don't have any more pictures but I created a Studio 2.0 file which you can download:
LEGO Technic - Mechanical Seven-Segment Tilt Display (v2).io
3 hours ago, aeh5040 said:
That's great!  An improvement on my version from 10 years ago!
Thanks, love your work!
Share this post
Link to post
Thank you so much for the Studio file, it's super helpful, finally I will have a chance to build this stunning creation.
Do you happen to have a Studio file for your amazing Cartesian Parallel Robot by any chance? I'm trying to rebuild it from the photos but I'm struggling a bit so far. I hope it's not too forward. Many thanks.
Edited by domleg
Share this post
Link to post
Thank you very much from my side I'll for sure gonna try to rebuilt this amazing thing.
@aeh5040: Thank you for your model also! It's quite a fun!!
Edited by teflon
addition
Share this post
Link to post
Sorry but I haven't modelled any of my other MOCs. If you have any questions, feel free to ask in the other topic :)
Share this post
Link to post
I always planned to make a multi-digit counter or a clock with mine, but never made much progress.  Really the design itself was a bit too clunky.  As you say, the key is to make a carry mechnism that is both reliable and can handle the torque.  I think this would be very much worth pursuing, and starting with your version ought to give a much greater chance of success!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
