Sign in to follow this
Coolusername
[MOC] Generic American Diesel Electric Locomotive
Over 4 years ago i builded this one, slightly based on the Maersk set. Its got a rechargeable battery, infrared sensor, 2 motors and a switch so one motor won't turn backwards.
Cab technique, i actually forgot over the years that these bricks have a 2l cheese inside them :D
This assembly is only attached with that lamp holder.
Edited by Coolusername
Share this post
Link to post
Share on other sites
So the switch pulled towards the plug reverses the forward motor?  Never did a double motor before and am in the process of building on myself.
Share this post
Link to post
The switch part itself has a little black switch in front. So it does not matter in which direction you turn the orange switch, since you can turn direction with the black one!
But there is also a version of that part with no black small switch! with bb0339c01  and without bb0339c02
I did the same thing with the Maersk set as well, both locos together and you can haul tons of rolling stock with it, as long as the locos are heavy and have some weight on the wheels.
And if you want even more traction, remove the bands from the wheels and try white rubber bands ;)
Share this post
Link to post
The one I have is the one without the black switch.  At this point, I think the switch is going to get buried behind the driver which is why I was wondering which way to set it.  The front motor is wired into it.  Surprised there isn't a mark on the switch to tell which way is forward or backward.
Share this post
Link to post
This is still very much a work in progress, but the only switch I have doesn't have the black switch and is hooked to the front motor.  Guessing the switch will be buried so wondering if it is set to make that motor go backwards.  Not sure yet on the yellow stripe and how I want to do the whole cab area.  I would test it myself, but don't have the space to set up a track at the moment.
Edited by CSW652
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
