Ex cinno Posted April 26, 2019 This time, after several models inspired by “Ferrovie del Sud Est”, I went back to the Ferrovie Nord in Milan and in particular their EB 700, a railcar that once Milanese commuters knew very well. With its 1285 pieces the EB 700 is so far the locomotive with the most bricks I've ever built. It's 7 studs large, as usually for my moc. Share this post Link to post Share on other sites
LEGO Train 12 Volts Posted April 28, 2019 Another great work Claudio! I've seen (and used) this train so many times in my life ...wonderful! Your construction technique has grown, I like that you have chosen to build in seven studs wide.The front part with the center door is very well done, as are the side doors ...the brown livery is a must! Share this post Link to post Share on other sites
Ex cinno Posted May 3, 2019 On 4/28/2019 at 7:42 AM, LEGO Train 12 Volts said: Another great work Claudio! I've seen (and used) this train so many times in my life ...wonderful! Your construction technique has grown, I like that you have chosen to build in seven studs wide.The front part with the center door is very well done, as are the side doors ...the brown livery is a must! Thank LEGO Train 12 Volts, I'm glad you appreciate my work and I was sure you knew this old locomotive. Share this post Link to post Share on other sites
Roadmonkeytj Posted May 5, 2019 This is beautiful both in RL and bricks! Well done i love that you used the yellow brick to simulate the tag. Share this post Link to post Share on other sites
Man with a hat Posted May 7, 2019 Nice work again. And some interesting and well designed details such as the "tooth" plate for the cabin. Share this post Link to post Share on other sites
Feuer Zug Posted May 8, 2019 Fine looking electric you've built there. The size looks good and the details well thought out. Share this post Link to post Share on other sites
Ex cinno Posted May 14, 2019 Thank you both for your kind words. On 5/7/2019 at 4:25 PM, Man with a hat said: Nice work again. And some interesting and well designed details such as the "tooth" plate for the cabin. On 5/8/2019 at 4:42 PM, Feuer Zug said: Fine looking electric you've built there. The size looks good and the details well thought out. Share this post Link to post Share on other sites
