CommanderJonny1 Posted March 11, 2019 Usually for something like this (i.e. a derivative of a design) I would put the other versions in the same post as the original, but in this case I only thought of doing a modification of my Scorpius MRV while I was working on its successor. After I went through that design, I went back and retroactively built the following versions of the original. Think of these additions as something akin to the Creator X-in-1 sets; in this case, a base model and the subsequent retooling that the Rebels did to add even more versatility to their arsenal. Here's the Mk IB-1; it's essentially the same as the 'A' model, although it would allow a commander/officer to stand in the middle. SW Scorpius Mk IB-C #1 by Jonathan Wallace, on Flickr Next is the Mk IB-2, the Communications/Electronic Warfare vehicle based off the Mk IB-1. SW Scorpius Mk IB-C #2 by Jonathan Wallace, on Flickr After that is the Mk IC-1, the troop/cargo carrier. Although not very effective due to its small size, it can still fit three 2x2 boxes, or up to three soldiers comfortably (you might be able to stuff a fourth in if they were standing up, but three is advisable). In addition, the tail mounted blaster cannon is operated by the pilot/driver, however it can be put on a lower mount so that the soldier in the back can man it; this blaster cannon is also meant to be removed if necessary (being taken by the soldiers to use in an attack). SW Scorpius Mk IB-C #3 by Jonathan Wallace, on Flickr Last is the Mk IC-2, a slightly bigger version of the Mk IC-1. This can hold four boxes, or up to four soldiers (as before, you might be able to stuff an extra one in). SW Scorpius Mk IB-C #4 by Jonathan Wallace, on Flickr If you want to build this for yourself, here's the instructions: https://drive.google.com/file/d/1qjOejLkC8vBtY-OSVEAHEsZPiJV0w4KA/view?usp=sharing And again, any feedback would be appreciated. Share this post Link to post Share on other sites
