Sign in to follow this
ProvenceTristram
[MOC] MECH 3-E "Kodiak"
Because when you have a problem, you call in the 'big white bear.'
... to, uh... make things worse. Since that's what bears generally do.
Ahem.
This particular unit is equipped for long-term reconnaissance, and features a habitability module "pack" with a small bedroom and additional supplies, as well as thrusters to allow the mech to ford rivers, or leap up cliff faces, etc. However, the pack can be removed and swapped for a number of different alternatives depending on the mission - everything from a flame-throwing nacelle, to a fugitive processing cage and interrogation chamber, to a miniature nuclear missile silo are at a commander's disposal. Yes, with the Kodiak, the world is your oyster... to smash open and devour raw.
Standard armaments include a four-barrel shoulder chain gun, quad anti-air/anti-ground short range missile launcher, and dual 100mm arm cannons. Oh, and a fist with claws. Meow!
Link to full-size original: https://i.imgur.com/xzUnvdR.png
The model is actually less than 500 pieces, which I would consider to be darned frugal for a robot that stands almost a foot tall.
Edited by ProvenceTristram
Share this post
Link to post
Share on other sites
Completely redesigned the cockpit. I never liked the single B-wing piece, and feel like this is a much better solution (it also allows for a navigator/gunnery officer to have an official seat below and forward of the pilot).
I wish that it was able to angle aggressively outwards about 45 from the top of the bubble, but after an hour of messing with it, I can't see any way to accomplish that while retaining the technique (stolen from the Jedi Starfighters) for the sides of the cockpit itself - the pieces necessary to accomplish any kind of a smooth transition simply don't exist.
Share this post
Link to post
I realize nobody is paying attention, but I did manage to overcome the angling issues by completely redesigning the torso of the unit. It's a little more cramped inside the front of the cockpit; substantially roomier in the back. There is still room for 3-4 figs, depending on their positioning.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
