Elana-chan
Layout: Planning multi-level, multi-theme setup.
Hey there. I'm working on the planning stages of a layout I plan to start construction on sometime in the next year or so, and I'm currently making the initial designs in BlueBrick. I have most of the main level finished, but I'm having trouble coming up with good methods to provide support for the different levels, as well as making room for some of the things I still want to add for detailing such as track side accessories. Another part of the puzzle I am having trouble finding an answer for is what the situation is for switches and weather or not setting the switches against a siding will disrupt the power flow to a 9V train sitting in said siding.
Here is the first draft of the design. The lower level will contain a space area on the lower left, and aquazone in the lower right, with the possibility for top center and right being a staging area for additional trains. Top left will be a helix for going between levels.
On the main area there is also a line going near the airport. This will be going uphill to a snowy/mountainous area. In the original concept, there was going to be a transition between the snow and space area via the iceplanet theme, but due to space constraints that won't be happening, but I would still like to put the ice planet stuff in with the snow area. For this reason I am also looking to figure out a way to make a ramp so non-rail vehicles can traverse between the space and snow themes. The snow area will be ontop of a mountain that overlooks the city level, and depending on how it's made, I might leave the underside of it atleast partially open, making an overhang of sorts covering the bottom level.
Edit: the break between the space and aquazone area is ment to represent a visual barrier that will likely also provide support.
Edited by Elana-chan
Share this post
Link to post
Share on other sites
Thanks, as part of the project I will be doing a mirror-build of the police pier, so that the boats dock on the side facing the bottom of the setup.
Edit: I'm curious what you guys think of how the rail system is going to end up being two end-to-end lines that meet on the main level instead of having a loop of some kind. The rail portion of it is designed with operations in mind, not just letting the trains run.
Edit 2: One of the large additions that I will be adding to this somewhere on the layout will be technic set 42055. Because it's more or less minifig scale I plan on putting it in as the centerpiece of a quarry, even if it doesn't have much room to manuver, I will atleast be giving enough clearance for the boom to rotate to some degree. One thought was to have the line up to the mountain be able to dump scoopable material which could then be sent via truck to the scale area to be loaded onto another train, or be taken by truck to the harbor after loaded into one of the modular hoppers from 4565. Given the nature of the cargo loads that came with that set, I decided to focus on using similar load types that use the 4x8 footprint and have something ontop that can be secured by a hook for being moved around by crane.
I originally thought about making 6542 and 4555 part of the layout, but after finding 6543 and thinking the area could use a place for private watercraft, there was nolonger room for both cargo ship docks. In addition to the space restrictions in the harbor, there was also having to choose the facility that came with 4565 or use 4555 instead, as there isn't room for both on the main level, besides, using the base from 4565 gave me a place to send the material that 42055 digs up! So it was down to choosing which type of 4x8 cargo to use, the type with a flat top similar to real-world shipping containers, or make things uniform with the type that gets carried around by cranes via hook, which allows for more versatile loads.
The only way I can think of to still include 4555 would be to somehow fit it in with one of the other themes on a different level, if I did that, one of those container forklifts would be needed on the main level sense there isn't enough room to put a stationary crane with the proper attachment there. And even then, there's no room for the dock that would handle that type of load. And last of all, I intend on using a smaller loading gauge for the trains, based primarily around 4559's clearances, so running any form of doublestack isn't really being considered anyway.
Share this post
Link to post
Here's a list of sets containing cargo that could be used with the chosen intermodal system with little to no modification, and is from a time period that matches the rest of the sets aesthetically:
1525: LEGO Container Lorry
6361: Mobile Crane
4030: Cargo Carrier
4563: Load 'N Haul Railroad
6352: Cargomaster Crane
6668: Recycle Truck
6539: Victory Cup Racers
4552: Cargo Crane
4557: Freight Loading Station
4995: Cargo Copter
As a side note, the truck from 4564 appears to be of the same design as the 6668 recycling truck, just with different loads to use with it. This could provide a limited addition to what can be swapped between sets.
I've also made the decision that due to the restricted size of the sidings at the main station, which is also the template for the rest of the layout my original idea of having two 4559 sets back to back in a formation similar to various high speed trains will be truncated so that there is still an engine at each end to facilitate not having to turn the whole set around, but the train will end up being shortened to only having two cars. The up side to this is that I can swap out the pods for daytime and night time use and have the entire train be sleepers or open seating.
Share this post
Link to post
Design update; I've defined a potential arrangement that would allow 42055 to be placed on the top level. The tracks ment to go to separate levels are now represented by having supports underneath. A pier ramp has also been added near the wind turbine to represent the loading ramp for swaping out the pods for 4559, the footprint is similar to eachother, the pier ramp is simply taller.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
