Sign in to follow this
Bartosz
7939 tanker wagon alternative parts
Hello,
I've recently started bricklinking 10016 tanker wagon. It's quite "bulky", and in the meantime, I've discovered that there was a nice, smaller one in the 7939 set. Even better than 10016 in my opinion, and a perfect to have couple of those!
But...
As usually, some parts are awfully rare. This time it's mostly about `Cylinder Half 3 x 6 x 6 with 1 x 2 Cutout` and `Dish 6 x 6 Inverted (Radar) - Hollow Studs` (87926 and 44375a respectively). Are any of you aware of some similar parts that could be used instead?
Share this post
Link to post
Share on other sites
You can play with the build in a program like Studio. You should be able to find a replacement part and you may have more luck using an alternate color scheme
Share this post
Link to post
I built a ton of these and used the 44375b instead of the hollow stud version. I also figured out a way to replace the 2434 with 5 very cheap pieces.
Share this post
Link to post
Ahh, forgot about solid/hollow variants. Also - what 5 parts? I thought about replacing with 4 30414 bricks.
Anyway, ordered parts for two of those, I can't believe I've missed such lovely wagons - the parts/price to effect ratio is pretty damn good :)
Share this post
Link to post
I used 4 22885 and you have to put a 2x4 plate under them to get the correct height. The 30414 should work the same though.
Share this post
Link to post
Right, I've used the 44375b too ...also in light bluish gray where the 44375a is really expensive
Share this post
Link to post
You made whole tank gray or just the cylinders?
Share this post
Link to post
Hello Bartosz, I assume you're talking about this design:
Theese wagons are color modifications of the original tank wagon from the 7939 set. (in my opinion one of the best cargo train sets ...) The design contains three parts which can make trouble obtaining them.
The cylinder 87926 needed four times for one wagon, the double sided snot brick 2434 needed two times and the 6x6 dish needed two times too. Since the studs of the dishes are covered by round tiles it is absolutely irrelevant if they are hollow or solid. Both bricklink and the LEGO sparpart service are full of affordable offers. Same for the both side studded modified brick 2434. It is covered over all by other bricks, therefore the color doesn't play any role.
The only remaining problem is the cylinder half 6*3*6. To get the wanted color you ned either a realy lot of money OR a lot of patience. The cylinder in dark red is nearly unobtainable at the moment. In 2015/16 the situation was different. More than 30 pieces were offered for more than two years on ebay and nobody wanted them. Ok, after several month I purchased 20 pieces for 5 tank wagons not recognising how rare they are! Perhaps in the upcoming years another opportunity occurs again - who knows? Hold on and look up ebay frequently!
If you have time until february, the spare part service of LEGO reopens. I can remember that cylinders 87926 are available in white, light bluish grey and tan (?) or dark orange, all colours suitable for tank wagons. The spare part service of LEGO ist affordable, quite often cheaper than most bricklink offers. So, wait for another 3 or 4 weeks and look into the spare part lists.
Over the years my collection of chemical plant wagons grows like this :
Share this post
Link to post
Can you take a close up of the red/black multi-cylinder tank car in the back row?
Share this post
Link to post
I also drained bricklink in europe last year to get light bluish grey 87926 parts.
Guilty :innocent:
Tanker Rail CarsTanker Rail Car
Edited by AE bricks
Share this post
Link to post
Yeah...I sort of dismissed it because of the yellow loco (which I didn't like) and never looked at its rolling stock. But now I'm also trying to use its container (the big one) design to build a cheap boxcar. We shall see.
Many thanks for photos!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
