LegoMonorailFan
Electrified third rail add on for Lego trains?
Has anyone ever attempted to make an electrified third rail add on for the existing train system? Something that would stud down onto the center of the track, and then a special bogie would pick up the current and deliver it to the motor?
Edited by LegoMonorailFan
Share this post
Link to post
Share on other sites
Would that be similar to the 12V system of power rails down the center of the track?
Share this post
Link to post
That's exactly what I had in mind.
Share this post
Link to post
you could just buy some center rails and add them to the powerfunctions/9v rails the curve radius is the same
Hope i helped
XGBC
Share this post
Link to post
@LegoMonorailFan I could see that working if you modified the track and fitted modified 0 gauge fishplates to the sleepers and threaded rail through them. Someone did something similar to make their own custom radius track.
Doing overhead centenary would probably be a lot easier though (less parts to modify).
Edited by Matt Dawson
Share this post
Link to post
That's possible, but not simple.
The contacs must be higher then the rails, but the contacts not be higher than the rails.
That' a bit difficult in case of switches, where the rails cross the track.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
