Sign in to follow this
knotian
Straight rail 3228
Forgive a newbie type question.
Why are the rails serrated on the top?
Was there any motor,wheel etc that was supposed to run on these tracks?
I would like to use these on some mocs (like overhead cranes) and would like to have some way to have a powered carriage run on these tracks. In the past I have used gears interacting with racks for motive power.
Thanx,
Ed
Edited by knotian
Share this post
Link to post
Share on other sites
Hi Ed,
some of the first ever produced Lego Train Wheels have been serrated also. On the first engines, back in 1969, there was no rubber-band around the wheels to improve traction. So my suggestion is that the teeth on top of rail have been created to prevent wheelslip.
Intersting about the curves. Inner side of track was smooth, while only the outer side was teethed. I think this was because the serrated wheel was so slip-proof, that the different length of inner and outer diameter created some problems if not one wheel was allowed to spin free.
Regards
BrickMusher
Share this post
Link to post
Since the two rails are different lengths, the other wheel had a longer distance to travel in the curve. If both wheels are spinning at the same speed, one must slip in order for both to arrive at the end of the curve at the same time (easily visualized by trying to roll a cylinder in a circle). The same thing happens in real railroading, though the solution is typically to use slightly conical wheels, so that the radius of the wheel can adjust slightly to the curves.
Share this post
Link to post
The 4.5V and 12V trains were designed to go up steeper grades, I think the official guidelines were one brick per 16 studs (rather than one plate of the 9V era) even after they went to rubber tires on the motor wheels.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
