Sign in to follow this
Technivor
[WIP] Caterpillar CT660 remake
Hi! It's been a while since I've posted here. I am currently reworking on my cat ct660 and I've decided to not do it RC. I've decided to make it a 4 axles and made the second one retractable but the problem I'm now facing is how to lock the steering on this axle. If you have any ideas don't hesitate to post something!
Here are some pictures:
DSCN4033DSCN4032DSCN4031DSCN4029DSCN4030DSCN4027
DSCN4028
Thanks in advance for any reply and have a great day!
Share this post
Link to post
Share on other sites
You mean how to lock the steering of the 2nd axle when it is raised?
I was walking by a parked tractor truck the other day, which had its 2nd axle raised and the wheels in almost full steering lock. I noticed that the raised axle was also turned! It was quite obvious when you were nearby, but from a distance you don't really see it because it turns into the mudguards.
I think real trucks don't lock/unlock an steering on raised axles, so maybe don't bother about it :classic:
(Maybe someone more knowledgeable can attest, but the complications of lock/unlocking steering on such big vehicles seems enough of an argument for not to do it...)
Share this post
Link to post
That is interesting because I had this dilemma long time ago. This makes also sense because usually rear axle can steer less than front 🤔
@Technivor so far your progress looks good despite I'm not fan of studfull chassis anymore
Edited by I_Igor
Autocorrect on stupid phone
Share this post
Link to post
You can use a gear selector mechanism just like in the transmission, between the HOG and a u-joint.
Edited by pagicence
Share this post
Link to post
Thanks for the replies and i think I'll choose to not make it lockable! It will make the build much easier and lighter.
@pagicence I thought about that but there would be too much play in the second axle' steering.
Share this post
Link to post
Ok, then how about this; use a #2 3L axle connector (32034) to bridge the 2L gap. When it's connected you will have 0.5L in each end of the connector, then you just move it to one side and the other side is free, and you won't get any play, lag or free movement in the second axle steering.
Share this post
Link to post
Not loking the axle is definately the simplest way to go. I've seen some designs that use two technic knob wheels (32072) that seperate when the axle is lifted. That way the steering stops.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
