I would like to present the result of my Winter-project. A big thank you to everybody who supported me in the corresponding WIP-topic and of course to @DugaldIC for challenging me!
Features:
  • Turn-table-based wheel-hubs with minimal slack
  • 4WD by means of 4 L-motors powered by two BuWizz 2 units
  • Fully independent suspension
  • Steering with Servo-motor
  • 30 degree steering angle with Ackermann geometry
  • Caster angle
  • Fake V8-engine driven by M-motor
  • Can handle a rough ride
  • Liftable by roof, nose and tail
  • Everything in-system
Stats:
  • Parts #: 1844
  • Weight: 1980gr
  • Length: 54 studs
  • Width: 35 studs
  • Height: 23 studs
I hope this will pull @Blakbird back into Technic :wink:.
LXF-file here and LDR-file here. @mj002, this includes all reductions I did, also to the chassis. I also removed the transversal inclined beams I reported about in the wip-topic recently. Eventually I could reduce slack in the rear suspension arm mounts much more efficiently and with far less parts. All together I reduced the number of parts by 200. I had to take the whole model apart to make all the adjustments :sceptic:.
If you want to build this from the LXF-file, please take notice of a few important pointers:
  • The 5.5L axles used in the front wheel hubs should be the old version. These are slightly shorter and can be recognized by more sharp axle-ends. As far as I know, all black ones are old ones. See also this topic.
  • To minimize wear, it is advisable to lubricate the turntables and the springs with silicon spray (don't use any other (petrol based) lubricants as they will react with ABS). Thanks for the suggestion @Permo!
Some stills from video-material.
And finally a few short videos.
Edited by Didumos69
Share this post
Link to post
Share on other sites
Epic ! absolutely epic Lego engineering !
Beautifull pictures.
So what will the next one be ? :laugh:
Share this post
Link to post
Fantastic! Its performance is almost like of a real RC.
How long does the battery last at full speed?
Share this post
Link to post
Hi
how did you solve the shutdown problem the the two buwizz?
Share this post
Link to post
The final product is just incredible! Excellent work! :thumbup:
The LXF is up to date, correct? (I would assume it is)
Share this post
Link to post
Thanks guys!
I have no idea. During the summer I will probably not do any serious Technic.
I shot about half an hour of videos at full speed without recharching and the BuWizz shows green/orange LED lights. I think it is about 2/3rd empty. So 45min. at full speed is the max I think.
I did not have that problem since I use the Brickcontroller app. It has a little lag, which makes it slightly harder to control, but I'm really enjoying it now.
It should be. Note that it has placeholders for the BuWizzes. I removed the transversal inclined beams I reported about in the wip-topic recently. Eventually I could reduce slack in the rear suspension arm mounts much more efficiently and with far less parts.
Edited by Didumos69
Share this post
Link to post
Incredible moc and wonderful pictures! The WIP topic was a lot of fun to follow as well.
Share this post
Link to post
Didumos, You are genius! No words. I must buy 2 BuWizzes. :)
Share this post
Link to post
13 hours ago, Didumos69 said:
@mj002, this includes all reductions I did, also to the chassis. I also removed the transversal inclined beams I reported about in the wip-topic recently. Eventually I could reduce slack in the rear suspension arm mounts much more efficiently and with far less parts. Effectively, I reduced the number of parts by 200. I had to take the whole model apart to make all the adjustments :sceptic:.
Thank you very much, I've been waiting for it already :wink: I'm going to look at the details, it'll be fun. At first, @Didumos69 just tell me, where do you install the small white rubber belt? OK , I can see it...
Great pictures!! The finished model looks very good. :wub:
Edited by mj002
Share this post
Link to post
They are wrapped around the U-joint axle holes 4 times, but apparently you already know.
Share this post
Link to post
I am fascinated by the work your suspension setup in first part of the video (the parking lot). it's reaction to the curb is just mesmerizing.
Good job!
Share this post
Link to post
We here at my household, we stands up and applaud to you @Didumos69!!!
Edited by sirslayer
Share this post
Link to post
Excellent!!! The only two problems I  (don't) have with it are two buwizz bricks :-) Fantastic tacklimg of those curbs. Pro-tag worthy!
Share this post
Link to post
Definitely a very cool build, I'm glad you enjoyed the RC side of technic! Thanks to you in working on both RC and HOG models for future builds. Although this greyhound is really only good as an RC, it really shows off the capabilities of a Lego offroader!
Share this post
Link to post
Good job!
Thanks guys! I'm indeed the most proud of how it behaves in turns and in taking curbs.
I'm planning to make photo instructions, but that will probably take a few more weeks...
Edited by Didumos69
Share this post
Link to post
Excellent work, the MOC performs like a real beast.  You should be quite proud of it - I think it takes Lego Power Functions components to their limit. :thumbup: :thumbup:
Share this post
Link to post
This really is in my view the pinnacle of RC technic. Really enjoyed reading your progress in the WIP topic, and the end result is incredible.
I know it's not going to be any comparison, but would this still perform even half as good with the usual AAA battery box?
As good an advert as this is for the Buwizz (really, they should be cutting you a cheque) I still can't justify the cost :(
Edited by JonathanM
Share this post
Link to post
6 hours ago, Isamudyson said:
Beautiful build. i will now have to invest in those springs and buwizz
Thanks for your kind words! A lot of the performance has to do with the BuWizzes of course, but I also did my best to minimize friction with a very simple drivetrain. Another thing I think is important for the final behavior is that I did not minimize weight to the absoulute minimum. Weight adds to the cars inertia and makes it respond lazy to bumps, just like a real car. Add a max steering angle of 30 degrees to that and you get a realistic body roll while cornering as well. The car's own weight makes it sink in its suspension for about 40%, which makes the car glue to the ground. Together with the 4WD this keeps the car going despite taking curbs or other obstacles. Of course extra weight decreases performance in terms of speed, but imo handling and roadholding are also important aspects of performance.
I don't know. If the seats are left out, the BuWizzes could be replaced with the 8878 rechargeable battery boxes and I expect the performance to be comparable with @agrof's Class 1 unlimited buggy or - when combined with SBrick - @Madoca 1977's Baja Trophy Truck, but I did not test this.
Edited by Didumos69
Share this post
Link to post
2x soft springs probably don't work. What about the normal hard ones from 8466? I am pretty sure those are still cheaper than the extra hard ones. Lucky I got them before they became so expensive :laugh:
Share this post
Link to post
For the rear softer springs certainly won't work and for the front I have serious doubts too.
Share this post
Link to post
Cool, it's on The LEGO Car Blog! I guess I have to thank @Lipko for this. Thanks! Some front-page-recognition after all :wink:, for in that regard I don't expect much from the moderators here anymore :grin:.
Edited by Didumos69
Share this post
Link to post
congrats for the moc, always curious for the implementation of that turntable based wheel hub
Share this post
Link to post
I added some important notes in the OP for people that want to build this from the LXF-file. Btw, I'm working on a LXF-file with steps in terms of groups. After that I will be making photo sequence instructions too.
Thanks!
Share this post
Link to post
Amazing!  I look forward to building it!  Looks like there was a good reason to buy all those used 9398's :grin:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
