Sign in to follow this
ShireBrickz
Advanced SNOT / Technique Help - Pyramid corners in 0.5 or 1 LDU steps
Hi Community,
I'm trying to resolve the construction of a pyramid type corner without using slopes, with each layer in two directions only stepping back either 1LDU or 0.5LDU whilst maintaining vertical alignment of face tile joints. Photos show what I'm trying to do but failing to keep the vertical tiles in alignment. Ahhh. This is doing my head in.
Edited by ShireBrickz
Spelling correction
Share this post
Link to post
Share on other sites
What do you mean exactly? The plates that are sticking out the back?
Share this post
Link to post
If you think about this a bit, you'll realize it's not possible to make the step in two directions while also keeping the tiles aligned. They are going to shift by the same interval as the steps. If your construction has steps in multiples of 20, then the offset will eventually "realign," but you will not be able to fill in the gaps.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
