Sign in to follow this
MattL600
[LOOKING FOR HELP] Sticker Hell
Well, I kind of broke a number of Lego parts by trying to remove the stickers.
I'd love to know how you guys remove stickers, I'm quite desperate for a solution. Especially with TC12 Near
Share this post
Link to post
Share on other sites
Using the tip of a sharp knife ease up one corner of the sticker, and then grip it with small pliers and slowly pull until you can grip with your fingers. It helps to warm the parts in hot water first.
I use this method to remove temporary route sign stickers on cycle routes and works for Lego stickers as well.
The key is a slow and steady pull.
Edited by Doug72
Share this post
Link to post
Peel it off with fingernail and then use the sticker to and fro againg on the piece quickly. This way the residual glue that is left on piece will get on sticker again. No need to use anything more. I bought a lot of parts from BL with stickers and this works like a charm.
Share this post
Link to post
If you're as bad at applying stickers as me, just stick your nail under a slightly loose flap and pull. If not, your nail should still do fine if you can get under the sticker.
Share this post
Link to post
WD40 works perfectly. I do recommend cleaning after using it though, because it tends to smell.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
