thekitchenscientist Posted September 12, 2017 (edited) After my previous attempt at entering this competition was ruled out, I made sure my new idea wouldn't suffer the same fate before starting to build. So what makes this entry wacky? All the wheels will be mounted as casters to give omnidirectional steering. Like a hovercraft the vehicle will be blown along rather than having driven axles. As is my creative strategy at the moment my build will be limited to the sets below. I am sticking to the pocket money range for my parts. This also keeps the larger sets free for my other build. It remains to be seen if I can manage casters on all sides of the vehicle. I'm thinking only two wheels on each face need to be casters as long as the remaining two have independent axles. Edited October 16, 2017 by thekitchenscientist Title Share this post Link to post Share on other sites
MangaNOID Posted September 12, 2017 Sounds good and wacky! It looks like your be putting the fan propulsion on it and not relying on wind power that could blow you to the back of the grid Share this post Link to post Share on other sites
mocbuild101 Posted September 13, 2017 I don't know what it's going to look like, or how wacky it's going to be, but if it's anything like your previous attempt, it should be great! Share this post Link to post Share on other sites
thekitchenscientist Posted September 14, 2017 A short building update. There were sufficient 15 stud beams in the sets to create a cube. My original idea was going to be more bowl like. It was to be made of triangles with a caster at each point. In the end the parts didn't speak to me in this direction. A range of casters have been fitted to four faces. The low profile tires allow for panels and lift arms to be used as axle mounts. Having two fixed, two rotating casters is more stable and not much less manoeuvrable than four rotating. I think I may go with this design for all the faces. Share this post Link to post Share on other sites
MangaNOID Posted September 15, 2017 I really like this! will there be a driver with a 'one way up always' seat? Share this post Link to post Share on other sites
mocbuild101 Posted September 15, 2017 I wasn't expecting that! Great work! Share this post Link to post Share on other sites
thekitchenscientist Posted September 15, 2017 The low profile tires have driven the next phase of this build. It may not look much different but the casters are now aligned on the non-panel faces. This has given the model a more defined front and sides. I had wanted to build a cube 30 studs to a side. This would have offered the driver a better view but I'm not sure it would be very strong. One of the things I like about this smaller design is the rigidity. 20 hours ago, MangaNOID said: will there be a driver with a 'one way up always' seat? You are indeed seeing my plan. I am working on this at the moment. Getting the balance plus style is not so easy. I was going to mount the fans in a gyro housing inside the cube with the driving seat in front. As other TC12 entries have found, such a mechanism takes up lots of space. I will mount the driver inside the cube and think again about how the fans might work. Share this post Link to post Share on other sites
thekitchenscientist Posted September 27, 2017 Finally made progress and got the driver and propulsion system mounted. As you can see I have reworked some of the colours to give each face a more consistent feel. The rear outriggers prevent the vehicle from rolling on its side. If trouble is spotted ahead the front brakes can be applied to flip the vehicle onto it's face. The driver seat also pivots and the racer can now operate in heli-mode and fly over the trouble. I'm still trying to decide if I should make the third mode all-terrain by swapping the top set of slicks for off road tires? Any helicopter experts out there tell me if the blades should rotate in the same or opposite directions? Share this post Link to post Share on other sites
Saberwing40k Posted September 28, 2017 Opposite Directions. That's how Chinooks work. Share this post Link to post Share on other sites
mocbuild101 Posted September 28, 2017 (edited) 11 hours ago, thekitchenscientist said: If trouble is spotted ahead the front brakes can be applied to flip the vehicle onto it's face. It's a car that can do a U-turn...without turning... Cool! 11 hours ago, thekitchenscientist said: the blades should rotate in the same or opposite directions? Normally they would rotate in opposite directions, but does it really matter for a wacky vehicle? Edited September 28, 2017 by mocbuild101 Share this post Link to post Share on other sites
thekitchenscientist Posted September 28, 2017 Thanks @Saberwing40k. That was how I originally built it, but it didn't look as pretty as both turning the same way. @mocbuild101 as you say, does it matter? I guess I was trying to give it a shred of believability. Share this post Link to post Share on other sites
thekitchenscientist Posted September 30, 2017 I think it is close to being finished. I've reworked each face to make them more distinct. The engine now has a fuel tank and quad exhausts. The blades now rotate in opposite directions to enable a hover mode, to get out of trouble. It also means I can drive straight up walls and cliffs. The third mode is back to being offroad or rapid U-turn depending on the situation. There is potential for a bit more greebling but I think the concept is complete. It is clearly a Racer and has some interesting features. Much to my surprise it ended up being the less popular sets that have contributed most to this model (stunt plane, record breaker, twin rotor helicopter, hydroplane racer). Share this post Link to post Share on other sites
thekitchenscientist Posted October 16, 2017 With the deadline approaching I have found time to edit a short video highlighting the main features: Share this post Link to post Share on other sites
trekman Posted October 16, 2017 I just loved the back up vehicle. It reminded me of Thunderbirds, where there was a little vehicle which came out of Thunderbird 2. I think you have thought of everything, and it makes me jealous, because it is a simple build, achieveable by many of us lesser eurobrick fans. Share this post Link to post Share on other sites
