I need to connect two sections of a mechanism where the axles are aligned x and +. They need to be in the same vertical axis but not necessarily the same horizontal axis.
Right now I'm using one of the old 24-tooth gears with three axle holes. This works, but I'm wondering if there is a more compact technique that uses a part currently in production. I've been away from Technic building for a while and am not familiar with all the new connectors. Is there anything out there that will do this?
After i search, i can't find any other parts that have that requirement. BTW, what will you build with that?
Edited by KamalMYafi
If you don't mind the axles being three studs apart, two of these might work:
As long as they're braced well, they should hold the 45° offset without too much slack. I sometimes use these when I need to actually undo a non-orthogonal gear arrangement.
I'm working on an escapement. This will attach a pendulum.
I'm not picturing what you mean
Or maybe one of many lifearms will do the trick; https://www.bricklin...P&catString=137
I was hoping there would be one of these little 2L arms with both x and + axle holes. The connection needs to be rigid.
This is similar to my current solution:
The whole thing rotates on the axle through the center hole of the 45-degree liftarm.
You can maybe use one of these types of plates http://www.bricklink...page?P=4263#T=C where you fix the axles position with a toothed bush. You can maybe even attach the liftarm of the pendulum directly on the studs of the plate and not need the lower axle. But it would of course have to be a liftarm with only pin holes.
I forgot about these! This should work:
Thanks!
Any other ideas?
I thought about those wheels too, but the angle is 60 degrees with those
Maybe one of those +\o liftarms suggested, but with an 8 tooth gear on each axle to fix the axles in their position.
Another one to answer the general query (though probably not helpful for the specific application), is to take advantage of the different orientations of the smooth and ribbed 2M axle joiners, along with a shifter ring:
Edited by Gnac
Similar to Gnac, I would also suggest a ribbed 2m connector, but inserted between the studs of a 2x2 round brick, and that should be all you need.
Edited by rodiziorobs
You could actually make it super compact by putting a toothed bush at the end of each axle and just put them end to end. But the rest of the construction might have to be pretty sturdy to keep them together.
