Hi! I started using inventor around 1,5 year ago. I was playing with different designs, mostly for my engineer degree. Then i make a excavator bucket based on Volvo bucket for ultimate 8043:
After that, i forgot about my project. I've lacked time and money. But this year's summer I printed it myself:
Then i started making new elements compatible with Technic:
Heavy Hook for GMK6400 Light hook made to replace Lego Metal Hook (part #70644)
Part in metal are very hard to make, because they expand somehow and doesn't hold dimensions.
Liebherr Wheel Loader Bucket for M_Longer L580 (slightly smaller than Lego Volvo Shovel, much bigger than part #32030).
Liebherr Excavator Bucket (little bit bigger than my previous excavator bucket, dimensions similar part #32030).
Rod 15L to use in trucks made by Ingmar Spijkhoven (which i also own - great trucks!)
And some teaser for my prototypes:
12 tooth sprocket, 8 tooth sprocket, blind pulley narrower than part #13971, rod to use in GMK6400 instead of part #6571.
I am also trying to entirely replace part #6571. If you have some new ideas about rare parts which are hard to get or very expensive I can help you.
Share this post
Link to post
Share on other sites
Looking good!
Do you have any photos of the 8043 with your bucket? Also, it would be nice to see your 2 sprockets lined up with the two existing sizes so we can see the variation.
Share this post
Link to post
Very interesting! I'm starting to see more and more custom parts, and it's kinda growing on me.
Share this post
Link to post
Looking good!
Yes, i have. Here are sprockets:
And here is 8043:
There is also film made by Technicbricks:
Share this post
Link to post
A good logical progression in size for the sprockets. Your digger bucket is also sized well on the 8043, a few mm different to Efferman's rock bucket. Nice!
Share this post
Link to post
That first excavator bucket looks wonderful in real - what kind of 3d print is that? I guess you used some of these laser liquid resin printers? Otherwise I have no clue how did you manage to print such part :D
Share this post
Link to post
on shapeways i recommend for the crossholes i a diameter of 4,9mm and the width of the cross 1,85mm. And if possible be sure the hole axis is vertical during printing or they will get oval.
Share this post
Link to post
Those were made with diameter of 4,9 mm and width of the cross 2 mm and they are still too tight. It looks like axle is stuck where material is thicker:
I wonder if making it diameter of 5 mm and cross 2,1 mm will be better?
Edited by xsysiek
Share this post
Link to post
with these dimensions still to tight? what is the wall thickness around the cross? do you have rounded the inner edges inside of the cross?
Share this post
Link to post
Outer diameter around the cross is 8 mm so it gives 1,55 mm minimum wall thickness around the cross. Inner edges were chamfered. But disk thickness is 3,5 mm and only in this part there is problem with axle.
Share this post
Link to post
Reduce the 3,5mm thickness of the disk to 1,2mm. Strong and flexible is solid enough to hold with this wall thickness. and in addition you save material which costs money.
Share this post
Link to post
I finished thinning sprockets and changed axle hole dimensions to d5 mm and width of the cross around 1,9 mm. Only saved 0,50$. Do you think I should make them in pairs? Now price is around 11$ for 12T sprocket and 6,5$ for 8T sprocket.
Share this post
Link to post
New parts arrived!
New Heavy Hook block is ready! Compatible with Lego Technic Metal Hook or with future add-on (double hook). Can be used with any of the wheels above (my or LEGO).
Substitute for LEGO part #6571. So you don't have to buy expensive and rare parts for Ingmar Spijkhoven trucks.
Sprockets version 2.0 (thinned). Little too lose, but after thin clear coating they should be OK.
If you have some new ideas, i am open to suggestions.
Share this post
Link to post
I'm interested in the wheelloader bucket, can't find it on Shapeways unfortunately, will it get on there in the future?
Edited by Dafgek81
Share this post
Link to post
If axles holes are undersized and oval, a "broach" is required to ream out the axle holes to the correct fit.
I use a Lego threaded axle as a broach to remove polishing dust and ease the fit.f
Edited by Doug72
Share this post
Link to post
@Dafgek81 Wheelloader shovel is public and ready to go. Walls are 1,4 mm thick. Front and sides are little strengthened, like in the original.
@Doug72 I don't have such parts. In future i will use effermans method to thinner walls around axle hole.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
