Sign in to follow this
IronFish
CSX EMD 70
This is a CSX EMD 70 train that I designed one day. I chose the CSX one mostly because I liked the coloring. There are several other MOCs of this train around the internet, but they mostly use 9V, and I wanted to do one that ran on Power Functions.
I did the mid-back section in a way similar to the Maersk train, so as to keep it thinner than the 6 stud front section.
The front section is made using SNOT
I made a section of the top easily removable, so I can access the battery box
I used SNOT several times throughout the train to get the shape right
A minifig can easily stand on the side of the train.
The one thing I need, is a decal I can stick on the side to give the train the CSX lettering, so if anybody could recommend something, I'd appreciate it.
Thanks for looking at my MOC!
Edited by IronFish
Please resize the images <= 1024 width first.
Share this post
Link to post
Share on other sites
That looks really good. Did you design it from the ground up, or did you borrow from something?
Do you have any plans to make siblings?
Edited by LoneBrickerSG
Share this post
Link to post
Thanks! I guess you could say it's a heavily modified 10219, because I started with that as a base, but I ended up with a whole new front section, and a whole new roof section, so it's more my design than anything else I guess. Edited by IronFish
Share this post
Link to post
Very nice indeed. I love the cab window. Very neat technique. Do you have plans to add some of Zephyr's CSX stickers?
Rob
That depends on what the dimensions are. Would they fit in a 4x6 area? That's about all the space I have.
Love the dark blue. I did a dark blue csx myself, they do look sharp.
Thanks! The dark blue was a little more pricey, but it was worth it in the end. Edited by IronFish
Share this post
Link to post
Hi Ironfish,
Great MOC!!
But your images are too large. EB's maximum is 1024 wide. Can you resize your images before embedding?
Share this post
Link to post
Hi Ironfish,
Great MOC!!
I've tried resizing them, but that never does anything, the pictures still end up being huge. I may just not be doing it right.
Share this post
Link to post
This is something I could see Lego selling. Its the right size for Lego and in 6 wide. Plus it comes standard with coffee mug like most Lego heavy machinery lol. Very nice engine!
Share this post
Link to post
I like it, looks good and it has the feel of an official set.
Thanks! The only thing, is I wish I could fix the plainness of the front area...
Share this post
Link to post
So the resizing probably failed. My advice is to use an image hosting site like Flickr or BrickSafe. They both allow you to upload in hi resolution and like to a scaled down version. Flickr is widely but you need some time to figure out how to link smaller versions. BrickSafe is very easy to use.
Share this post
Link to post
I'll have to try that next time, thanks!
Share this post
Link to post
Great!
Since these images are too big, I recommend trying it right away :wink:
Share this post
Link to post
Rob
That depends on what the dimensions are. Would they fit in a 4x6 area? That's about all the space I have.Thanks! The dark blue was a little more pricey, but it was worth it in the end.
Doh! I missed that discussion my first time through. I think the large "CSX" in my decals are about 10 studs wide (I can get exact dimensions if needed). I designed them for a Maersk repaint, but they should also work for a similarly sized MOC. The nose artwork is designed for flatter builds (e.g., the Masersk nose) while yours looks like it has a one plate high jump. So it probably would not work in this case.
Share this post
Link to post
thank you, but I don't think I have enough room for it, because there aren't any bigger flat tiles in dark blue.
Share this post
Link to post
Nice work, I really like the color combo!
Thanks! I like it too!
Sorry, I never caught that last bit. As of right now no. With the way the train is designed makes it hard to do stripes, chevrons, and other details of the other main train companies, without decals, and that's one of the reasons why I picked a CSX train was the simple coloring. Edited by IronFish
Share this post
Link to post
The thing about decals is that all you need is a color printer; MS Word, gimp, photoshop etc. ; google images/other image site; and some sticker/ decal paper for the printer. Just find a picture of the logo online, put it into MS word etc. and make it the size you want, then print it onto the sticker/ decal paper. That is how I did these: 11259818983_ed1daab760_c.jpg
The trick is to make the colors match with the LEGO ones which is where Gimp or photoshop would be better.
Edited by engineermax
Share this post
Link to post
For some designs (typically black lettering is best) you could even use clear sticker paper to avoid having to match colors. When you start doing logos with lighter colors it doesn't work as well, the brick color fades through more.
Share this post
Link to post
Very nice colors indeed! I love the design of the cabin. Well done!
Thank you!
I'll have to do a bit of my own research on doing a decal for the train, but thanks for the tips!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
