Jurss
[WIP] OSCar Dakar
http://driveeo.com/oscar-eo/
Color scheme close to this
as i don't have so much blue and white parts
Of course 4x4 . Original car uses two electrical motors, each for front and rear axles. I will use also 2 motors for drive. XL for rear, L for front trouhg reductor, because it has higher speed.
Servo motor for steering, of course.
Maybe M motor will be also used, because
Permanent Magnet Synchronous Generator with 1 power inverter
  • Nominal output 80 kW
  • Driven by Nissan VQ35DE IC engine
  • 240 litre safety fuel tank
and then it will be placed as generator, but will just drive the engine.
Until now, biggest challenge is front axle (maybe just for me), with independent suspension.
Some first try
When this was seemed pretty OK, created rear axle and and putted together some chassis
then theres concept of motors palcement
Then theres some concpet of steering trough gears
it was not OK, because steering angles was pretty small. Gear ratio wa not main issue, because on one side there was conflict between diffrentiel gear and steering rack.
Then i came to this idea
And now i can use full possibilites which are limited buy this original connection
This red
is used, for better control. With this the rack is hold still, theres no gap between those grey L type parts. That was the best part form my collection to use. I tried also smallest gear, but it had some cons.
And now biggest challeng - building of cabin.
It wont be so hard, if i had smaller wheels, which would be similar to original.
I have tyres from 42037-1, but those are with round profile, not square.
Share this post
Link to post
Share on other sites
Interesting steering setup :thumbup: :thumbup: (last two pic's)
But I think the axles are too far apart. Will keep my eyes on this thread :classic:
Edited by Siegfried Meyer
Share this post
Link to post
You mean front and rear axles? If so, for me it looks also, that they are too far, but the wheelbase is comapared to wheel size of original, and the wheelbase now is already shorter (specially shortened), than on original.
The original has ~3,5+ wheel D
My model has ~3 D
Also front axle setup will be improved, because it is allready possible to shorten it by one position. This is built on first version with steering rack. And it was allready late, when i made this.
I forgot to mention, that my company, in which i work, is sponsor for this team.
Share this post
Link to post
well,This is built on first version with steering rack. And it was allready late, when i made this.35.gif
Edited by srseekvve
Share this post
Link to post
Why don't you just use another xl for the front axle? What advantages does this set up have?
Share this post
Link to post
Naldy997 - the reason is - i just don't have another XL motor yet
srseekvve - yes, it is/could be so, but the lenght also is shorter. I thought about to make it wider, but i'am allready worried about making cabin, because i don't have lot of panels.
Share this post
Link to post
Made it even shorter. Started to build cab
All main yellow parts which i have
Share this post
Link to post
Rebuilt steering system, so it could be possible to connect steering wheel. First idea was, that i will connect steering wheel to other side of servo motor, but it was too complicated or maybe even just impossible. This was better solution.
Lowered front part by one stud
Made openable hood/bonnet (at beginning it wasn't so, but then i found one picture with this opion, and had to do it)
Chassis strenght improvements (later i added two more, which are coming from back to front, those are possible to see in further pictures)
Power station as on original, which is driven only by to electrical motors, and there is electrical generator to chagre batteries, which is driven by Infinitys V6
And this system has cooling
And then there's some cabin progress
To do:
- better pictures at daylight
- interior
- lot of ether small tuning
Share this post
Link to post
Your doing a good job, it's really starting to take shape! The only thing I don't really like too much is that you went with a lot of stacked beams to fill up holes. You don't need to fill everything up to make it look like the real thing. For example, looking at TLG's sets, lots of them are quite open and they still look nice (most of them anyway :tongue: ). Other than that, keep up the good work, can't wait to see how it does driving! :wink:
Share this post
Link to post
Nice, and clever cooling system! I never thought of that, I might steal the idea to make a custom intercooler for my new pickup.
Don't steal, just take.
Share this post
Link to post
Cons of this system:
- bad control, because there is bad connection between wheels, they are living diffrent lives, it just bending on those axles
- ball joints are slipping off those yellow parts
Don't use this system
Steering system and dashboard
Seats
Some improvement to rear suspension - four yellow parts to fix suspension in place
Bye bye
Share this post
Link to post
It looks as though ther is quite a lot of bend in the body? Or are you using a wide angeled camera? Other than that it looks pretty cool!
Share this post
Link to post
Yes, there is little bend. There are X type strenght structure inside, and this was best position, which i could get.
There are lot of copromises in this bulid - steering, bodywork, weak drive (it needs some at least 2 XL motors, or better 4, i have only XL and L), no pleasure to drive. I'll better bulid something smaller, faster etc.
It's just too big, or i'm not enough patient :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
