Hi guys, I am looking for some ideas on making a arm that will allow a truck ramp to up and down,the real problem is that it needs to work of a crank arm and there is not much space to work in.
I did manage to get some movement but not all that I require.
You need to join on to the black crank and link it to the actuator bracket
Any help will be much appreciated. :classic:
ramp.lxf
Do you have a picture which shows how it should look?
I don't have a finished picture,you are free to do as you like as long as uses the crank in the picture which links to the LA bracket.
Something like this?
If you turn the lowest gear they all turn and it folds out. (the fancy colours are for clarity :wink: )
It is the ramps at the back I need help with not the crane.
I will try that, but it would of been better with some sort of arm linkage,thanks. :thumbup:
Here's my version of the mechanism Mark was describing:
I don't think your design is going to work that well,again some sort of linkage is the ideal solution.
But thanks anyway. :thumbup:
I built one and it works pretty awesome, fun to play with. Try it out, you might be surprised. The only down side is that the gears are kind of large and out of scale, but some 8tooths should work just the same, as long as there is an even number.
I made a basic prototype for the dubble folded truck ramp, see the video below.
Not sure if it fit into your build but atleast its one way to do it :)
I will try that idea later.
Well that is what I had wanted but I ran out off room,so now I am looking for alternatives.
Edited by Alasdair Ryan
