Covenant84 Posted July 17, 2014 Posted July 17, 2014 Hi all, Trying to do something for work but my ideas haven't worked. Could anyone make the following logo for me out of lego (LDD) and let me know how. Requirements: Needs to be as small as possible (Fewest bricks). Best colour match as possible. All pieces must e available in pick a brick. If a deign is used I will of course credit the designer. Thanks! Quote
The Undo Posted July 17, 2014 Posted July 17, 2014 Here's a quick idea. I couldn't think of anything smaller than this. I hope it helps. And i'm not sure if all of the bricks are available in pick a brick, but they're made in standard LDD mode so i guess they could be. LDD file Quote
plew2000 Posted July 17, 2014 Posted July 17, 2014 (edited) I have made one using very few pieces. However I cannot seem to put a link on here. I will try again. Edited July 17, 2014 by plew2000 Quote
Covenant84 Posted July 18, 2014 Author Posted July 18, 2014 Thanks guys! Any more also welcome, ideally with a single top layer but as close as possible is just as good. Keep trying plew2000 - I've had that problem myself, in the end I've copied and pasted the link from photobucket straight into the reply box and not using the forums 'insert button and that seems to be working. Otherwise pm me and I'll send you an email add. More responses still very welcome! Quote
Covenant84 Posted August 6, 2014 Author Posted August 6, 2014 It's not bad, definitely fits with budget requirements, although I'm not sure the people at the top would accept as it's maybe a little too adapted from the flat design. Very good attempt and if were up to me I'd be happy..... Quote
