moosmahna Posted May 25, 2014 Posted May 25, 2014 Hi everyone! This is my first topic an first of all sorry for my english :-) .I built a little truck and now i tried to put a motor on each of the axles in 90 degrees! I have studied a lot of building instructions and forums bit i had no luck! Can you please give me a little help or a starting point? Thanks a lot! Quote
JM1971 Posted May 25, 2014 Posted May 25, 2014 The lego switch can be used to reverse motor polarity, so you can put all the motors on the same channel, depends on the design. This is something I would like to do but never found a way to make it work, so GL. Quote
moosmahna Posted May 25, 2014 Author Posted May 25, 2014 Hi JM1971! Thanks for your answer! I am looking for a simple way to put a motor to an axle! In the smallest range! I am new to LEGO technic and want to start from the beginning! Thanks again! Quote
D3K Posted May 25, 2014 Posted May 25, 2014 With modern parts, I don't think you can get much simpler than this: Quote
moosmahna Posted May 25, 2014 Author Posted May 25, 2014 Hi D3K I know the way you showed! But how can i put the motor 90 desgrees to axle? Quote
D3K Posted May 25, 2014 Posted May 25, 2014 Hi D3K I know the way you showed! But how can i put the motor 90 desgrees to axle? That is 90 degrees to the axle? aka perpendicular I don't quite follow what you are aiming at... Maybe a picture of your little truck woult help clarify things? Quote
Alasdair Ryan Posted May 25, 2014 Posted May 25, 2014 That is 90 degrees to the axle? aka perpendicular I don't quite follow what you are aiming at... Maybe a picture of your little truck woult help clarify things? I think he would like the motor turned 90 degrees to the frame. Quote
moosmahna Posted May 25, 2014 Author Posted May 25, 2014 You are right! I will try to make some photos tomorrow! Photos are much better for explaining :-) Thanks Kind regards Hi Ryan! You are right! 90 degrees to the frame! THANK you for translating me!!! Quote
Kelkschiz Posted May 25, 2014 Posted May 25, 2014 I am also not quite sure what you are aiming at, but if you want to attach two M motor to two axels you might want to take a look as Mahj tanks chassis. He managed to attach an M motor in a very compact way to an axel, Quote
D3K Posted May 25, 2014 Posted May 25, 2014 So you want the output of the motor to be in paralell with the actual axle, sort of like this: ? Or is there something I'm not getting Quote
Alasdair Ryan Posted May 25, 2014 Posted May 25, 2014 So you want the output of the motor to be in paralell with the actual axle? Or is there something I'm not getting That is right. Quote
moosmahna Posted May 26, 2014 Author Posted May 26, 2014 Thanks for your help. My idea is that the axle from the Motor is 90 degrees to the driving axle. So the M-Motor Comes from the top .On the axle from te M-Motor should be a 20 tooth double bevel (piece number 32269) and on the drivin axle a 12 tooth bevel (Piece number 6589). And I want to use this idea for the 2 axles on th rear wheels. Quote
