Good morning,
I have recently moved to EV3 from NXT and have realized that the hi-technic PID block does not work for EV3.
So, I tried creating my own and have run in to all sorts of problems and am here looking for help or advice.
Here is what I would like it to do,
Calibrate - move a motor in a direction (to a hard stop point) reset the degrees. and make this the datum 0 point for all new move references
Move - move using the datum from the calibration point a set amount of degrees.
I was trying to use two degree reads 0.1 seconds apart, subtracting them using a math block then comparing it to a set value of 5 degrees to measure no movement. all contained with in a loop, using the compare to break the loop. It dont work argggg.
Please help
any ideas?
Hello
The code below should work as a calibration (99) and move (98) function.
The move block is just a P regulator and not a PID regulator as the old one from hi technic but in most cases its enough :).
With the "range" block you can set how accurate you want the move function to be, however i dont think you can go lower then -2 and +2 becouse it might get stuck in the loop depending of the P value.
I have only run the code a few times so i'm pretty sure that it's not perfect and it will probably not work with a daisy chained motor.
I hope it is of some help.
/Hknssn
