I am sure this question has been asked and answered, but I don't have the time to do an extensive search. After a long hiatus from buying Technic I recently picked the 42009 Crane. However, I have heard from a friend at TexLUG that the L-motor is underpowered and that the XL-motor having a lot more torque would be a better option.
Is it possible to install the XL in the L's place when assembling. I haven't assembled it as of yet, so wanted to ask the experts here their opinion and if it is possible before I 'bury' the motor when putting it together since it is such a massive kit.
Thanks in advance,
Eric
I have not had any trouble with the L-motor, so I'm not sure where you got your information. The XL motor is a lot bigger and would require extensive modification of the gearbox.
I haven't had any problems with it being under powered, seems to do just fine for me. Keep in mind the motor is in the upper structure, so if you build the lower and later find the motor is not up to your liking your only talking rebuilding the upper part like Mr B said. Oh good to see you back, hope everything is going good.
Alright then, thanks guys for the input. I got that info from a review on Lego S@H or an Amazon review, can't recall, but if the L is fine that's great.
Thanks again.
