I have been working on and off on this for a couple of weeks now, and it is not finished (see the back), but I find myself in dire need of yellow arts for other projects, so unfortunately I won't be able to finish it :cry_sad:
This is my first go at making a plane, so please bear with me.. it is by no means a beauty :blush:
Its features are:
-Rotating prop directly connected to a flat-4 engine.
-Realistic flight controls (elevators, rudder, aileron) controlled from cockpit
-Retractable (well, sort of) landing gear
-Weight brick in the front to keep the nose down
-Shiny exhaust pipes
The elevators and ailerons are controlled by a stick in the cockpit, and the rudder by pedals.
I made a quick LDD model of the mechanical side of things:
The purple is the ailerons
Red is elevators
Green is rudder
Making a plane was very much fun, so hopefully I'll be able to make a better one in the future! :laugh:
That's great looking! It needs wheels on the inside of the landing gear but apart from that it's a good job. I hope you can finish it as you would like. I've discovered i'm rubbish at aircraft but will try a small copter.
H
Edited by Horace T
