Hi folks, hi efferman,
my U406 covers arrived today. The pieces are in a good quality the surface is a little grainy. Next timeI'll order the polished version. But a little sanding and paint and everything will be OK.
The rewards go to efferman. He did the job designing them. THANKS!!! And all the best for the coming days!!!
But take a look yourself.
On the weekend I'll paint them in RAL 3020 which match stye Lego red best.
So far
Pat
Edited by Pat-Ard
The cross hole was a bit grainy. I just tried with an axle and after some doing the axle fits... I didn't even needed a file...
The bolts look good, you have to take very close look. I think they'll come out better if the covers are painted...
And again!!! THANKS!!!
Pat
My order came in today: four of your U500 covers. They look good as well, I made the axle holes a bit bigger and sanded the surface lightly. This weekend I'll paint them and put some images here of the finished product on my 8110.
Edited by Cumulonimbus
Hello Efferman,
I hope you are alright in the hospital. I am going to order the parts, I have 1 question.
Can you maybe make a bigger LA? Or is this too difficult?
Thanks, iam fine. The bigger linear aktuator should be possible, and iam working on one with a stroke of 15 studs, but it needs a lot of material. So it willnot be cheap.
on the actuator everything is experimental and the size is more for a crane like 42009. before to think about different lengths, it has to work. especially something like the overload clutch. this is the point which iam stuck
a new rim for 49,5x20 in difference to the original rim, now with six hole mounting. pivotpoint of the 42000 steering hub is now directly on side of the tire
edit:
and a part for quick couplers
Edited by efferman
