thrakkazz Posted January 22, 2014 Posted January 22, 2014 Hi, probably this one would give a better idea of what's the ship looks like (to my point of view, sadely i've not found any numbers related to the structure, only aroud 800m long) http://battlefront.wikia.com/wiki/File:Harrower.png Quote
kr-lik Posted January 22, 2014 Author Posted January 22, 2014 yeah i see that... it's a bit more "pointy" I guess... maybe I'll try to do the "flat" version just using the plates and build a skelleton on that... thanks! Quote
Brickdoctor Posted January 22, 2014 Posted January 22, 2014 In regards to the alignment issue, it happens because somewhere in there, there's a piece that's somehow been rotated just ever so slightly (Probably on the starboard edge near the stern, would be my guess.), but since LDD will let you attach something if you get 'close enough' using the Hinge tool, then it lets you do it, and eventually adding more parts magnifies the problem until you end up with what you see there. If you can remember using the Hinge tool somewhere, then I'd remove that section and anything attached to it and reconstruct it for starters, otherwise, the only thing I can suggest is to pull off chunks of the build near that area and put them back and see if that fixes it. Quote
ISDAvenger Posted January 22, 2014 Posted January 22, 2014 If you look at a picture in the Old Republic Guide Book, it shows the engines being round, which IMO look much better. Quote
kr-lik Posted January 22, 2014 Author Posted January 22, 2014 so... i did what i said i would: looks better no? :) Quote
Commander Colt Posted January 22, 2014 Posted January 22, 2014 An interesting ship design to undertake, good luck on your quest to complete this! Quote
Fuppylodders Posted January 22, 2014 Posted January 22, 2014 That does look a lot better regarding the angles! Quote
planetes Posted January 24, 2014 Posted January 24, 2014 Out of curiosity, what size scale are you using for this? i.e. how long do you expect the final ship to be? Quote
kr-lik Posted January 24, 2014 Author Posted January 24, 2014 I think it will be more or less the size of the old ISD... It's 89 Studs long lol (just counted) Quote
kr-lik Posted February 5, 2014 Author Posted February 5, 2014 heh... LDD is one damn pain in the ..... hinges just DON'T WORK in it... I even tried to do the construction from the 10030 UCS SD as I wanted to base on that... but I can't seem to fit them hinges... :( Quote
