Hi,
today I started with the first floor of mine "snackbar" but I got some troubles to add some stairs to the second floor. Maybe some one in here can give me some tips and trics to solve it?
I did check the tutorials, but I was not able to figure out how to place the pictures right here, so check mine fresh flicker for the picture :-)
sorry for the bad quality of the pictures.
Regards
Asterix
Edited by iNsAnE_Asterix
Do you want the stairs in the snack bar or as a separate entrance to upstairs? Most modulars use either a few brick built steps and then a LEGO stair case attached to a wall or a completely brick/plate built spiral staircase. The spiral takes up little space but many pieces and can be fiddly to make strong. LEGO stairs are strong but bulky.
In your bar I think an outside staircase if the upstairs is separate or a spiral in the corner of the bar are your options.
Cheers
Rog
