I'm working with another gentleman on nailing down this issue. I believe I know what it is, just waiting to hear back from him on the test fix.
if you PM me your IP, I can check with my web host. I got locked out of my own website for about a day when I was setting it up. :sceptic: I might need to switch hosting companies. I don't know of any that offer $2.50/month plans, though. :laugh:
Just posted version 0.92. Here's the link: https://docs.google....X3otZ3hiT2FjN2c
Changes in 0.92:
  • New toolbar
  • The progress bar is now more granular when calculating.
  • Fixed another bug in importing wanted lists (oops).
  • Fixed a bug with displaying (or lack thereof) millions of matches checked.
  • Matches in excess of the "Matches per combination" setting are pruned to save memory. Some very large lists were running out of memory before finishing calculation.
  • Can now change status (by double clicking), condition (by double clicking), quantity, price, comments, and remarks. Also, deleting a line properly deletes the item. Stay tuned for more list creation and modification options.
  • Items with status "x" will not be included in calculation.
  • There is a button/menu item that will allow you to view the current/previous report. While calculating this will show any calculation levels that have completed, but not the current level.
  • Added more error checking and debug info
  • Calculation can now be cancelled at any time. The report will reflect any matches found at the current level.
  • Names of stores for any given country are now cached between calculations (in addition to cached price guide pages that I failed to mention last release)
  • Removed option to save bsx from the import window (don't worry, you can still file -> save as once it's imported)
  • You can now double click a wanted list name in the import window to import it.
  • Fixed a bug that would crash calculation if there were less items than the store combination you were searching for. You can now find a good combination of stores to buy 10,000 of a single piece from.
  • Backend stuff nobody cares about.
Hi Mdoupe,
I started following Brickficiency from reddit and finally downloaded 0.92. This is the first time I am using brickficiency and I have encountered a strange problem. So when I click on "View Report", the default browser (tried both Firefox and IE) pops open and gives the "Parts list sorted by number of stores" but does not show the stores. Hopefully you can help me out. Thanks!
Edited by sshamsi
...if you PM me your IP, I can check with my web host. I got locked out of my own website for about a day when I was setting it up. :sceptic: I might need to switch hosting companies. I don't know of any that offer $2.50/month plans, though. :laugh:
$2.50 a month!?!? That's a steal!
I pay $5 a month for my server and I find it a very good price. Two domains are included (worth around $20 a year).
IP has been sent to you.
When you ran the calculation, did it say that it found some matches?
I'm not sure it's worth it if people randomly get blocked. :)
Well I discovered something for those having issues with the program quitting with an error that it couldn't read the part file. There is a part of my brain that knew numbers were represented by "5,8" instead of "5.8" in other regions, but I assumed C# would just go ahead and convert "5.8" to "5,8" when operating on a french language OS. I was wrong. I will have to figure out a way to convert "5.8" to a decimal variable regardless of region. It might take a few days though, as I'm a bit busy at work.
I want to note that the error I submitted earlier in the topic (about the report with wrong prices) still exists. Although the price is correct now, it misses a "," or a "." :wink:
having a bit of a problem. have .92 version. did the import and put in my username and password and it gave me the option of all or main for wanted list to import. i have only one list, but either one that i try, when i hit import the console window in the bottom almos immediately comes up with 'Found 0 Lots in 0 Lists
0 items in 0 lots imported.'
any ideas?
Hi and thanks for looking into this problem!
do you have any other wanted lists besides the default "Main" wanted list? If not, try creating one. It doesn't have to have any parts in it, just needs to exist. I found that bricklink returns wanted lists differently if you don't have any lists besides "Main".
I installed the latest version, launched it, it downloaded the parts catalogs from Bricklink, and then it gave an error saying it could not open the parts list file.
I get the same error whenever I try to launch the program :sceptic:
I've posted a new test version that I think should fix the problems launching the program, and possibly the problem where the price guide pages aren't being read properly. Check it out here: https://docs.google.com/uc?export=download&id=0B6HH_wCQ4odGLTFKT0NrcnlTWTA and let me know if it works.
Also, sorry for the long silence. I've been away on work for the last week.
I've posted a new test version that I think should fix the problems launching the program, and possibly the problem where the price guide pages aren't being read properly. Check it out here: https://docs.google....LTFKT0NrcnlTWTA and let me know if it works.
It worked for me using a fairly small wanted list and restricting the search to USA stores.
it did indeed fix it. i created a second wanted list other than just my main one and it gave me a list of all,main, and the second one i created. when i selected 'all' it loaded both my main and the other list.
i was a bit curious tho. i'm not sure how it's getting it's prices but sometimes even with the 'cheapest' combination it's WAY too expensive. it appears that it doesn't take into account the price of the part. for instance i was looking for the partout of a 7$ set and if i were to buy the parts by looking at just the prices it would run me about 15$ for the parts (plus shipping) but it's cheapest was almost 90$! when i looked through some of the parts it found, they were way over priced...i did however only do 4 searches but man o man....
I should clarify, it only searches the cheapest matches for the number of stores you're searching. IE. if all of the pieces on your list are available from exactly 1 store, but that store has ridiculous prices, it'll tell you about that 1 store and then quit happily. that's why I added the option to keep searching higher numbers of stores -- if you're not happy with the 1 store solution, it'll go on and check 2 stores, and 3 stores.
Out of curiosity, which set are you referring to, so I can test it out myself? I'll never rule out the possibility that Brickficiency is broken. ;)
aww man, it's been a few days since i did that search and i don't remember which one it was. i'll be sure to keep an eye out for some crazy behavior and definitely let you know. as i said, i had only done 4 combinations so i'll be sure to try more than that if i get some crazy results before i flag it. :)
I am glad you left the option to continue searching after the match was found. I needed a few more pieces to finish a moc. Just 18 pieces. Easy right? There was only 1 store that had all of it but the total came to $9 before shipping. 2 stores option had combined total of $2 before shipping. Guess which I bought from? 2 store choice (after checking their splash page for lot limits, fees, etc, had to disregard the first 2-stores solution as they had $20 minimum buy). The grand total with shipping is $7 combined, less than one store solution.
Note: I was still using 91 when I got this error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: This BackgroundWorker is currently busy and cannot run multiple tasks concurrently.
  at System.ComponentModel.BackgroundWorker.RunWorkerAsync(Object argument)
  at Brickficiency.ImportBLWanted.nextButton_Click(Object sender, EventArgs e)
  at System.Windows.Forms.Button.onmouseup(MouseEventArgs mevent)
  at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
  at System.Windows.Forms.Control.WndProc(Message& m)
  at System.Windows.Forms.ButtonBase.WndProc(Message& m)
  at System.Windows.Forms.Button.WndProc(Message& m)
  at System.Windows.Forms.Nativewindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
   Assembly Version: 4.0.0.0
   Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
   CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Brickficiency
   Assembly Version: 0.90.0.0
   Win32 Version: 0.90.0.0
   CodeBase: file:///C:/Users/Lion.O/Desktop/Brickficiency.exe
   Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
   CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
   CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
   CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Xml
   CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Core
   CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
   CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.GeneratedCode
   Assembly Version: 1.0.0.0
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
   <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Happened when I tried to log in to pull wanted list.
Another issue, and this one can be blamed on BL and not the program. Some European stores add VAT to part price and some don't so this can screw the result. For me in USA, any item that comes up with VAT included already, I need to manually calculate estimated difference (usually 19% off). Slows me a bit and I may miss cheaper deal because Brickficiency doesn't have a way to tell if the store includes VAT or not and can't account for that.
and for people in Europe, some of the cheapest result may not include VAT so buyer beware...
I got it to start running a search with the test version - .91 & .92 kept having the unhandled exception error for me.
It doesn't seeem to like searching for boat anchors though, I had to take that part out to get the search to run??
Sorry, it does it with other parts also:
Available from 205 stores
Getting Price Guide information for Black Plate 6 x 10
Available from 196 stores
Getting Price Guide information for Black Plate 6 x 14
Available from 237 stores
Getting Price Guide information for (Not Applicable) Plate, Modified 1 x 1 with Clip Horizontal (thick open O clip)
Error: (Not Applicable) Plate, Modified 1 x 1 with Clip Horizontal (thick open O clip):Either this is not available from any stores you've selected or you need to log in.
Some items were unavailable. Calculation cancelled.
I am logged in to Bricklink??
Edited by ummester
Ok, it seems to be something to do with the color - for some reason Brickficiency is loading up certain parts with a non applicable color. I have saved a .bsx file and manually gone through it to make sure every part has a color and then saved a copy but Brickficiency still opens it with non applicable colors?
Edit, sorry, worked that out I also had to change the color ID numbers. Does anyone know the colour ID number for dark blue/earth blue?
It now seems to load all images and is running with a 2.600 piece wanted list - it is very strange that the colors don't import/export properly, however.
And, after running this for a while:
Getting Price Guide information for Dark Bluish Gray Door 1 x 4 x 6 Barred with Stud Handle
Error downloading price guide (got page, but there was nothing on it)
Shouldn't the program interrorgate the stores, regardless of there being nothing on the price guide? - or is there a way to make it continue the calculation, even when it can't find a price guide for a given part?
Edited by ummester
Finally have it running away - I had to cut out any parts that were in less than 20 stores. But it has been running for more then half a day:
Calculating 5 store solutions...
Millions of solutions checked: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742 743 744 745 746 747 748 749 750 751 752 753 754 755 756 757 758 759 760 761 762 763 764 765 766 767 768 769 770 771 772 773 774 775 776 777 778 779 780 781 782 783 784 785 786 787 788 789 790 791 792 793 794 795 796 797 798 799 800 801 802 803 804 805 806 807 808 809 810 811 812 813 814 815 816 817 818 819 820 821 822 823 824 825 826 827 828 829 830 831 832 833 834 835 836 837 838 839 840 841 842 843 844 845 846 847 848 849 850 851 852 853 854 855 856 857 858 859 860 861 862 863 864 865 866 867 868 869 870 871 872 873 874 875 876 877 878 879 880 881 882 883 884 885 886 887 888 889 890 891 892 893 894 895 896 897 898 899 900 901 902 903 904 905 906 907 908 909 910 911 912 913 914 915 916 917 918 919 920 921 922 923 924 925 926 927 928 929 930 931 932 933 934 935 936 937 938 939 940 941 942 943 944 945 946 947 948 949 950 951 952 953 954 955 956 957 958 959 960 961 962 963 964 965 966 967 968 969 970 971 972 973 974 975 976 977 978 979 980 981 982 983 984 985 986 987 988 989 990 991 992 993 994 995 996 997 998 999 1000 1001 1002 1003 1004 1005 1006 1007 1008 1009 1010 1011 1012 1013 1014 1015 1016 1017 1018 1019 1020 1021 1022 1023 1024 1025 1026 1027 1028 1029 1030 1031 1032 1033 1034 1035 1036 1037 1038 1039 1040 1041 1042 1043 1044 1045 1046 1047 1048 1049 1050 1051 1052 1053 1054 1055 1056 1057 1058 1059 1060 1061 1062 1063 1064 1065 1066 1067 1068 1069 1070 1071 1072 1073 1074 1075 1076 1077 1078 1079 1080 1081 1082 1083 1084 1085 1086 1087 1088 1089 1090 1091 1092 1093 1094 1095 1096 1097 1098 1099 1100 1101 1102 1103 1104 1105 1106 1107 1108 1109 1110 1111 1112 1113 1114 1115 1116 1117 1118 1119 1120 1121 1122 1123 1124 1125 1126 1127 1128 1129 1130 1131 1132 1133 1134 1135 1136 1137 1138 1139 1140 1141 1142 1143 1144 1145 1146 1147 1148 1149 1150 1151 1152 1153 1154 1155 1156 1157 1158 1159 1160 1161 1162 1163 1164 1165 1166 1167 1168 1169 1170 1171 1172 1173 1174 1175 1176 1177 1178 1179 1180 1181 1182 1183 1184 1185 1186 1187 1188 1189 1190 1191 1192 1193 1194 1195 1196 1197 1198 1199 1200 1201 1202 1203 1204 1205 1206 1207 1208 1209 1210 1211 1212 1213 1214 1215 1216 1217 1218 1219 1220 1221 1222 1223 1224 1225 1226 1227 1228 1229 1230 1231 1232 1233 1234 1235 1236 1237 1238 1239 1240 1241 1242 1243 1244 1245 1246 1247 1248 1249 1250 1251 1252 1253 1254 1255 1256 1257 1258 1259 1260 1261 1262 1263 1264 1265 1266 1267 1268 1269 1270 1271 1272 1273 1274 1275 1276 1277 1278 1279 1280 1281 1282 1283 1284 1285 1286 1287 1288 1289 1290 1291 1292 1293 1294 1295 1296 1297 1298 1299 1300 1301 1302 1303 1304 1305 1306 1307 1308 1309 1310 1311 1312 1313 1314 1315 1316 1317 1318 1319 1320 1321 1322 1323 1324 1325 1326 1327 1328 1329 1330 1331 1332 1333 1334 1335 1336 1337 1338 1339 1340 1341 1342 1343 1344 1345 1346 1347 1348 1349 1350 1351 1352 1353 1354 1355 1356 1357 1358 1359 1360 1361 1362 1363 1364 1365 1366 1367 1368 1369 1370 1371 1372 1373 1374 1375 1376 1377 1378 1379 1380 1381 1382 1383 1384
Is this normal?
WHOA! I don't know if it's normal but I wonder how long did it take for you to go through 1384 million possibilities. I usually gave up much sooner and try to figure out a way to "help" the application by pinpointing the "problem" (usually some rare parts).
Oh you just said, more than half a day...whoa, that is a lot of patience on your part.
For really large want list, I'd run Brickficiency and do just 1+2 store combination. Odds are it'd get 0 result and display list of parts you needed. The list are conveniently sorted by fewest stores first so if you took a few of the rarer parts and moved it to a second want list (label it rarer parts or something), then run it. Limit to 4 stores at first. Hopefully with fewer rare parts the program can hit something worthwhile by 4 stores.
5 stores can take too long on large wanted list. Do this only if your wanted list fails to come up with 4 stores or better combination, and do it at night just before you go to bed. Disable auto-sleep just in case.
There is an unfortunate balancing act with Brickficiency... Too many rare parts and you will not find any matches. Too few rare parts and it takes FOREVER. As an upside, you can cancel it at any point (by clicking the dollar sign with the red dot on it) and it will list the cheapest matches it's found so far. I'm sure there must have been some decent matches somewhere in that 1.3 billion. :)
Someone else was working on a similar program with a vastly different approach. Instead of iterating through every combination of stores, it would "tunnel" through stores adding them to the current combination (if valid) until it hit the depth you specify (ie. if you're willing to buy from 10 different stores, you set the "depth" to 10). Once it hit the maximum depth, it would either pass and save or fail and discard that match and then move on to another. I'm not sure how well it worked, as I never had a chance to use it and when I tried that approach, I failed miserably. :)
I'm still working out some kinks in importing wanted lists. Unfortunately, I'm also working on a pretty large build for a show, so I haven't been spending much time coding.
The price guide is where Brickficiency gets all of it's information about which stores a part is available from. If the part is not available from any stores, there are no stores to interrogate.
The part "Dark Bluish Gray Door 1 x 4 x 6 Barred with Stud Handle" has never been made by lego: http://www.bricklink.com/catalogItem.asp?P=60621
Edited by mdoupe
Thanks mdoupe,
I do appreciate the program - I appreciate any help in trying to sort out the pieces for a very large MOC.
I did work out about the door after I posted it, sorry. There are some things that LDD manager accept that aren't on Brickling and some things on Bricklink that aren't on LDD manager, I've been designing in LDD taking LDD Manager and Bricklink into account but certain parts will always be oddities I guess - I changed the door to pearl dark gray to be sure.
Anyways, Brickficiency is still going on the same wanted list, I left it overnight - it's up to 2462 millions of combinations now It didn't find a match on 4 stores, it can't with this wanted list. I don't want to stop it because I wan't it to spit out something,
Is there a way for me to set in the options that I wan't a return on the store that has most of the pieces on my wanted list, for the best price? Top 5 by number of parts and price, rather than trying to fill the entire order.
