drdesignz Posted September 13, 2012 Author Posted September 13, 2012 Thanks for the support. 33 is pretty good for the first ~24 hours. I'm quite happy with that Quote
kieran Posted September 13, 2012 Posted September 13, 2012 Really captured a classic Hot Rod, or what I think of as a hot rod in that, it's also cool that is is a display piece with power functions, rather than the typical drive around car. You get my vote. Quote
Aussie BJ Posted September 14, 2012 Posted September 14, 2012 Number 45 supporter here. Well done on a great MOC. I really like the colour choice and tyres (Australian Spelling ) Would love to see it beside the 8070 Supercar B model. Again great MOC and good luck on Cuusoo! Brendan Quote
drdesignz Posted September 14, 2012 Author Posted September 14, 2012 Thanks! I'd like to build the 8070 hot rod one of these days. I'm curious to see them next to each other myself. Quote
drdesignz Posted September 15, 2012 Author Posted September 15, 2012 I had some yellow pieces left over and a few hours to kill, so I built this little one: Quote
bord4kop Posted September 15, 2012 Posted September 15, 2012 Very cool!! Even better than the big one Just kidding, BOTH are very very nice, excellent work there! Quote
TimH Posted September 17, 2012 Posted September 17, 2012 Awesome work! Love the detail of the engine Quote
kieran Posted September 18, 2012 Posted September 18, 2012 Looks amazing, so simple but manages to capture the look and feel perfectly Quote
Ballast Posted September 18, 2012 Posted September 18, 2012 So many details and still the minimalism of a hot rod. I like the mini fig head on the shifter Quote
Sandyu Posted April 10, 2017 Posted April 10, 2017 On 9/11/2012 at 8:55 PM, drdesignz said: Weeell, it does, sort of, but it's minimal. Maybe a millimeter? Haha... it had more, when I first designed it. I built the car from front to back. It became heavier than I intended, so now the front end just barely hovers over the surface. I thought about raising the front height by adjusting the shock position. But then the steering geometry and other parts had to be adjusted too, so I decided that was too much work. Besides, the car's stance looks pretty mean the way it is now. One day I may decided to rebuild the whole car from scratch, to resolve these minor issues it has. Thanks much! It just got a approved a few seconds ago: lego.cuusoo.com/ideas/view/25263 I think your model shows a lot of work and imagination, but I have some helpful (I hope!) suggestions to help you reduce that weight in the front. First, the front tires are really way too wide, they should be only about half that width (or even less, if you can do it). The radiator shell should completely contain the radiator (actually, be integral with it), and that radiator shell is way too tall -- by about half. The firewall seems to be three layers thick, when it needs to be just one (the widest one). I’d suggest a bench seat, as well -- which would be lighter with no console. And I’d lose that useless trim around the rear wheels, too, you don’t really need it and it doesn’t really help the appearance. Also, you have the doortop not quite flush (or the same height) as the rest of the body for some reason, though it should be, and you have door handles!! (Gotta lose those!) You have individual zoomies, when you ought to consider block-hugger headers. (A LOT of weight to be lost there!) And you have 2 fuel lines to the injectors when all you need is one; plus, the injectors could be integral with the scoop. Try adding a tach but losing 2 of the smaller gauges. If you try all this weight-loss I bet your front end will work just fine, and without your adjusting the steering!! Quote
brickless_kiwi Posted April 10, 2017 Posted April 10, 2017 This models radiates traditional 32 highboy with a hemi. with just the right stance! Quote
