Hello,
I have a quite big problem with LDD that I probably caused myself.
Background of the problem:
I was trying import a LXF file with a more than 12K (12000+) bricks into new file where was approx. same amount of bricks (crazy, isn't it?). It was so slow so I tried change the priority in Task manager from normal to real time (even more crazy). After few seconds LDD crashed without error.
Consequences:
LDD up to 1 minute is loading file with only 1 brick and the same for the other files. Also this same goes for import and save. (The loading bar fills up fastly but after it is filled LDD "stops working" and after a minute work normally) Only files created before this "accident" loads, import normally.
I don't know what else could do this problem so I think, things I mentioned above caused this because after reinstall the problem still exist.
Can someone help me please?
Consequences:
Just a try:
* close LDD and uninstall it
* go in "Application Data" folder (open an Explorer window and write "%appdata%" in the address field, without quotes). Locate a folder named "LEGO Company" and delete the folder
* locate a folder named "temp" in your user folder (in an Explorer window write "%temp% in address field), delete all files in it.
* Reinstall LDD and launch it
Except the "temp lxf files" and 2 files that's I've been working on last days, it looks like it worked or at least it looks faster.
Thanks, much appreciated.
(Temp lxf files - files where is done most of my work so that mean, it is saved over 20 times because if I create a file (for ex. Ambulance.lxf) and stuck in "creativity" or forgot/doesn't look what i wanted, I simply remove it and can be replaced by other model without deleting/replacing file --- only if someone wondering what I meant)
(only a small note - importing one of these temps into another one cause LDD crash)
