Back in 2003 I bought the gear set 10076 from Lego. I always wondered how to use these 2 gears that came with it:
41666 - Light Gray Technic, Arm 1 x 7 with Gear 9 Tooth Double Bevel Ends
41667 - Light Gray Technic, Arm 2 x 5 with 1/4 Gear 8 Tooth Double Bevel
Any insight would be informative. Thanks.
(Tried showing pics but can't link off of bricklink.)
I've experimented with those 2 parts for making door opening mechanisms... In the 41666, you can connect another bevel gear to one end and you can make the entire thing move back and forth by turning that gear... The 41667 is very similar to the gear that is used in some automobile's power window regulator... I think these 2 parts have some untapped possibilities... :wink:
Edited by Paul Boratko
