webtoad Posted December 18, 2011 Posted December 18, 2011 I want to use the 'GATE 4x8' in a model although can't wok out how to get it hinged properly. What piece(s) should I use to get it hinged? I tried using 'FLAT TILE 1x4 W/STUBS VERTICAL' although couldn't get that to connect on. Quote
DLuders Posted December 18, 2011 Posted December 18, 2011 The LDD part labeled as a "Gate 4 x 8" is known in Bricklink as the 6105 "Door 1 x 4 x 8 Curved Top". On that Bricklink webpage, I clicked on the hyperlink that said "This Part Appears in 2 Sets (View Them)". I clicked on the 6082 Set Inventory to see what hinges come with that gate/door. There are several different "Plate, Modified 1 x 1 with Clips" in that set, so I went to http://www.Brickfactory.info to see specifically WHICH Modified Plate is used with that gate/door. From the 6082's Building Instruction Page 6 below, it turns out you need an unusually-shaped brick to clip onto the gate/door: Going back to the Bricklink 6082 Set Inventory, I see the black 3581 "Brick, Modified 1 x 1 x 2 with Shutter Holder". Since the Bricklink part names sometimes don't match the LDD names, I did a search within LDD for the term "1x1x2" (with no spaces between the characters). The 3581 part appears on the short list. Quote
Alasdair Ryan Posted December 18, 2011 Posted December 18, 2011 I have attached a file below with the door and brick attached,You can use the 'hinge button' to rotate the angle of the door to your needs,you can find the brick and door in the 'door category'. Quote
Superkalle Posted December 18, 2011 Posted December 18, 2011 The LDD part labeled as a "Gate 4 x 8" is known in Bricklink as the 6105 "Door 1 x 4 x 8 Curved Top". On that Bricklink webpage, I clicked on the hyperlink that said "This Part Appears in 2 Sets (View Them)". I clicked on the.... Now, there's a bit of detective work for ya. Quote
