So, this is my first build that I post here. I like building trucks and fiddling around with them, so the moment I saw the 6753 truck, I knew i had to build it. However, Im still thinking that there is something missing, so if any of you has suggestions, feel free to post them. Also any tips on improving the design are welcome too.
Front
Rear
PS, any moderator/admin, I just found out that this is in the wrong section, so can you please move it to the right one? Sorry for the mistake.
Cheers!
Mikey.
Edited by Calabar
Oversized images converted in text links
This should be the right section, but you have to share the lxf file.
If you don't want to share it, the right section becomes the... mmm... the creator theme section, probably!
Another thing.
The rules of the forum allows images not bigger than 800x600 pixels. You should resize your images or use thumbnails.
Well it started with a creator set [...]
eh, as I said it was a creator set then! :tongue:
Anyway, I'd prefer to see this topic in the LDD section, with the lxf file shared! :wink:
Righty, as usual, the rebuilding got out of hand. and the only thing unchanged is the cab design, everything else got overhauled. Its not slightly longer and has many other updates too. still debating on wheter to build a trailer or not. But im sure I'll do it. But the truck it self is more-or-less finished.
