On 9/10/2022 at 7:30 AM, efferman said:
maybe
btw, the new head is arrived and works like a charm. The material is PA12 in a multi jet fusion print looks good, but the versatile plastic in SLS is much more solid. One of the towballs is broken.
This weekend i will make the 5 blade version of the flat rotorhead.
edit: the 5 blade is available at shapeways: https://www.shapeways.com/product/EHWVBDXJB/flat-5-blade-rotorhead
@efferman that is incredible.  Very nice. And I love that you colored the top.   I will watch the progress of your large bird with anticipation, and likely will purchase one of these rotors.  But I have to complete my version of the Airbus first.  I am trying to incorporate your swashplate into it, along with some other changes I am making, but it will take a while as things in my own career and family have sped up.....
this was the colour of the Gray PA12 printing process.  fits good to DBG
On 9/25/2022 at 7:41 AM, efferman said:
I guess i found a way for compact tailrotor collective Pitch control
Very coool!  Is this going to be implemented in the new bird you are working on?
16 hours ago, efferman said:
I guess, yes
:thumbup:  Keep us posted.  I am curious how you will carry the collective out that far.   Taking both power and collective out the length of the tail to the tail rotor will be a challenge....
On 10/9/2022 at 8:27 PM, efferman said:
Found some time to finish an instruction.
Great work again, impressive build. I don't fully understand why there are two motors; I expected the movement of the axles and the hitch assembly to be coupled via a linkage. Or did I miss something?
There are three motors. One L for the Kingpin Lift, one L for the axle lift, and one M for the parking stand.
The king pin lift and the axle lift are not connected because there are different fifth wheel heights, which makes an adjustment neccessary.
7 hours ago, efferman said:
I made a decission to make bigger blades.
i hope i will find a solution for printing without selling my kidneys.
Why don't you buy yourself an FDM or cheap resin printer?
Most hobbyist printers couldn't print anything that long in one piece, I don't think (though the awesome conveyor belt ones could!) Though I do think standard printers are very worth the money to people with uses for them.
Great work as always Effe. I'm interested in building a heli-rotor with both collective/cyclic. Your shapeways page shows few options.
What parts are required to build a 4 (or 6) rotor system?
Thank You.
Kidneys are overrated.  This looks awesome.
Thank you very much. I just ordered them, along with your Torsen differential. The holidays will include some Lego time :)
One more question. What parts I need to support the blades? I'm thinking something similar to this Lego part, with more attachment options.
Edited by DrJB
Use the same system like in the 42145.
Made a little bit on the sikorsky front.
