21 hours ago, I_Igor said:
shield from Arocs
this is still to find.
Actually iam not sure about the size of the Cab, but the tire should fit to the set and the scale.
edit:
the bonnet is in io
Edited by efferman
This should even fit for the 19 stud scale, when  something big will built.
edit:
Edited by efferman
That suspension solution is imho tho most realistic since there is no lego leaf spring.
694506-f0dab5d41b2f76176ccc9e8f4d011fd0.
Edited by I_Igor
4 minutes ago, Scoar Sonander said:
Did you design the tires?
The tires in the Render are shrinked Version tires. To get a 80 mm Version.
Motors? Maybe 2, maybe 4
1 hour ago, Scoar Sonander said:
I wonder if they're going to use the new diffs for the Zetros...
Don't know, but I know that Michael will make zetros before official release :wink:
Well if he does, he'll show us how good the LEGO set could have been, and kick the official set's a$$ in comparison :laugh:
Keep it up, I like watching your progress :thumbup:
Edited by Gray Gear
Well, hopefully he will release instructions...
We will see.
btw, Long live the Overkill!
What’s the deal with the 6x pulleys on the drive shaft? Is that to help with the amount of torque the u-joints will be put under?
It allows the driveshaft to change its length when the Suspension is working.
Edited by efferman
