Looks good are you going to share what functions you plan on having?
Compressor
Slew
Legs
Mayby rear legs
Rasie lower legs (this would mean you are going to build new legs)
That is only five functions out of eight.:sweet:
Edited by Alasdair Ryan
only four functions, because i only want control the crane and the outriggers. I think with the next two pictures you will see it more clear.
it is not complete, the levers will be centered by rubberbands, to let the functions stop, when it is no finger on the lever.
Why are you using four gear driving ring's/gear change piece's,this takes up a lot of room,you should only need two gear change piece's.:classic:
Ah clever German engineering again.:laugh:
:laugh: :laugh: .
Nice progress. I would never have thought to have a mechanical solution to what is often solved electrically.
tim
looks even better. is there anyway to bring the crane just a little closer to the wall? Or will the crrane arm go there? At the moment it looks a little empty :sceptic: .
tim
I actually think it's an ok distance away, as the Grapple ( forgotten real name ) will go there when the crane folds back on itself. Or at least I prosume it will.
