mkrogers64 Posted August 9, 2011 Posted August 9, 2011 EDIT: Unrelated quote and image of Emerald removed by moderator. My Emerald night engine seems to bind and does not run well. Is there someway to get it working better. My emerald night engine does not work well. It is hard to get it started and it seems to bind. Does anyone have any ideas about how to get it working better. Quote
WesternOutlaw Posted August 10, 2011 Posted August 10, 2011 Mkrogers64: There's a number of topics related to issues and improvements for the Emerald Night here in Train Tech. I would recommend you take a look at the Index to see just a few. Here's one of many that provides a solution if you did not use the recommended 12:00 / 3:00 wheel alignment per the instructions. It solved a lot of my problems with sputtering and locking. NOTE: I've also moved your initial question posted to topic: My Emerald Night Gold line Mis Printed to this topic. Please refrain from starting multiple topics or posts regarding the same question. You might also introduce yourself as a new member in the Community forum and/or Train Tech Registry in this forum. Much appreciated. Quote
